Members Constabulary Posted October 10, 2021 Author Members Report Posted October 10, 2021 (edited) In my has I only had to adjust the needle bar height but it is fiddly because the NB is governed by a V shaped cam but I got it back to live and it worked very well. But when your needle bar is technically okay you do not need a new one just for using 135x17 needles. My old NB worked with 135x17 w/o problems. I only replaced it cause it bent when I tipped over the machine. On 10/8/2021 at 2:49 PM, ddiuni said: If I replace the 'Singer Part # 4264' needle bar, can I use the 34K5 sewing machine with needles of various sizes? sure. I have used needle sizes up to NM 140 but again if you current NB is functional you don´t have to replace it just for using different needle sizes. 6 hours ago, ddiuni said: Is the 34k2 sewing machine usable for leather sewing? Watching the YouTube video of 34k11, I can see that even thick leather is sewn. I want a machine like this, can the 34k2 I got this time also sew thick leather? A 34K11 is a much much heavier machine than the 34K2 or 34K5. it weights approx twice as much as a 34K5 and the 34K11 (system 328 or 214x1) is using a needle system that the 34K2 or 34K5 cannot handle. The 328 needle is much longer it does not work in the other 34K machines. How thick is your "thick leather" - in total, not single layers? Edited October 10, 2021 by Constabulary Quote
Members ddiuni Posted October 10, 2021 Members Report Posted October 10, 2021 (edited) 6시간 전 경찰은 이렇게 말했다. 그 쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쯧쩝 독서실 135x17 쾨쾨쾨이 쾨쾨쾨쾨쾨쾨쾨쾨쮾ꩍꩡ NB는 135x17 중요합니다. '더 인더우먼'을 가인더스트리얼. ㅇ. NM 140까지 뚱뚱한 소리를 NB가 뚱뚱한 소리를 하기 시작했습니다. 34K11은 34K2 또는 34K5보다 더 많이요. 무게는 34K5의 약 두 배 34K11(System 328 또는 214x1)은 34K2 또는 34K5가 시스템을 사용하고 있습니다. 328 길에서 34K를 택했습니다. 당신의 "두개운"은 한 가지씩 총 몇 개입니까? I am going to receive this 34k2 sewing machine soon. It works, but I asked because I thought it would be hard to get additional needles. So if you change the needle bar, you can use needles of various sizes. But I don't know what the original needle type of the 34k2 is at the moment. It doesn't appear in the parts list and there doesn't seem to be a user manual. When I watched the YouTube video, I saw a video where the 34k11 sewing machine sews leather quite thickly, so I asked if the 34k2 was possible. Please tell me what type of needle is the 34k2 or 34k5. Edited October 10, 2021 by ddiuni 의사전달 미흡 Quote
Members ddiuni Posted October 11, 2021 Members Report Posted October 11, 2021 On 2015. 11. 8. at 오후 9시 39분, Constabulary said: 나는 최근에 오래된 34K 포스트 베드 기계를 복원했습니다. 불행히도 나는 그것을 화나게했고 지금 바늘대가 구부러져 있습니다. 다시 바로잡을 방법이 없습니다. 그래서 교체가 필요하지만 예비 부품을 더 이상 사용할 수 없다고 가정합니다. Singer 17 또는 18 클래스의 바늘대가 적합하다고 가정하지만 100% 확신할 수 없습니다. 그래서 제가 여러분에게 묻고 싶은 것은 Singer 17, 18, 31, 16, 128, 96 또는 이와 유사한 기계의 직경과 길이를 측정하여 측정값을 비교할 수 있는지 여부입니다. 내 34K 바늘대의 직경은 0.285" 또는 7,24mm이고 총 길이는 8 3/4" 또는 22,3cm입니다. 감사 해요!!! Ali Express sells 7.23mm in diameter and 228mm in length. However, since the diameter is not 7.24mm, vibration or sound may occur when moving. This is for singer 31K, 44K and 331K. Quote
Members ddiuni Posted October 11, 2021 Members Report Posted October 11, 2021 18 hours ago, Constabulary said: 내에서 나는 바늘대 높이를 조정해야했지만 NB가 V 자형 캠에 의해 통제되기 때문에 성가신 일이지만 다시 살아 났고 매우 잘 작동했습니다. 그러나 바늘대가 기술적으로 정상이면 135x17 바늘을 사용하기 위해 새 바늘대가 필요하지 않습니다. 내 오래된 NB는 135x17 문제 없이 작동했습니다. 나는 기계를 넘어 졌을 때 구부러져 있기 때문에 교체했습니다. 확실한. 나는 NM 140까지 바늘 크기를 사용했지만 현재 NB가 작동한다면 다른 바늘 크기를 사용하기 위해 교체할 필요가 없습니다. 34K11은 34K2 또는 34K5보다 훨씬 무거운 기계입니다. 무게는 34K5의 약 두 배이며 34K11(시스템 328 또는 214x1)은 34K2 또는 34K5가 처리할 수 없는 바늘 시스템을 사용합니다. 328 바늘은 다른 34K 기계에서 작동하지 않는 훨씬 더 길다. 당신의 "두꺼운 가죽"의 두께는 단일 레이어가 아니라 총 몇 겹입니까? I read the reply again. You are saying that the DP 135x17 needle can be used even with the existing needle bar. Then there would be no difficulty at all in purchasing a needle. and I looked for shuttle carrier #82372 to see if there were any parts, but it doesn't exist anymore. However, only #81952 and Bobbin #82552 can be purchased on Ali Express. If you search for 29k, you will find it. Quote
