A seventeen dollar length of 4x6. A 79 cent hinge and a couple of hours in the shop and I have myself a European style stitching clam. I totally see what the fuss is with these things. Very comfortable and ergonomic
post-14104-0-73548800-1449616485_thumb.j
post-14104-0-45360300-1449616546_thumb.j
Edited by tboyce
Nice job. Guess you used a copeing saw to cut it out ? 😁
Edited by dirtclod
I'm old enough to know that i don't know everything.
Be careful T.....you may have to go into business making these now. Jk
Greetings from Central Texas!
The Grain Side Up blog
#TheGrainSideUp
Nice job you should put the hole and the staple in it to put your stirrup leather. The job is way easier when you strap it to a bench and put your foot in the stirrup. Can't seeme making a set as I have about 30 of them in my school. Again great job well done
www.uksaddlery.com
Saddlery training courses in Dunoon Scotland UK.
Very nice, I am jealous. Looks great. Are you going to put any type of finish on it? Can show a picture of the hinge attached?
I'm still refining the process. in the one pictured, the wood was cut to 1-1/4" thick. I just finished drawing up another one that I will make out of solid maple boards glued together to make a solid block that I can cut out. Since it will be hardwood and, because of the boards glued together, I figure it will be much stronger and so I have reduced the thickness to only 3/4"
When I'm done, I'll post the process in pictures and a pattern
amazing how easy it looks... I might have to try to make one
Thanks
Lew
