Uwe Posted December 24, 2015 Report Posted December 24, 2015 I made little sewing demo video (partially in the hopes of it helping sell my Chandler/Adler 67-GK373 + FESM-550 servo motor setup.) The video may be useful to others who are wanting to use french seams. I'm just practicing on vinyl before I use them on my leather bags, but they're starting to turn out pretty nice. Here you go: Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Northmount Posted December 25, 2015 Report Posted December 25, 2015 Nice video, as usual. You can strengthen French seams by adding a reinforcing strip behind the seam. Then the joining seam is not taking all the stress when subject to being pulled across the seam, and the seam won't tend to open and gape. I recommend it. Makes a much stronger and durable product. You can also use a pressing stick to help separate the join and to press it flat before doing the side stitches. Much like a burnishing stick. Really like and appreciate your videos. Tom Quote
King's X Posted December 26, 2015 Report Posted December 26, 2015 Nice demo....thanks for sharing! Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
Members paprhangr Posted December 27, 2015 Members Report Posted December 27, 2015 Thanks, I learned something new from your vid. Trying to explain. I have had some difficulty when sewing around the English point belt end. Your techniques showed me I can raise the feet BEDORE BURYING THE NEEDLE, giving me a view WHERE I AM, with the the need close checking the needle position, adjusting /moving the leather as needed, then set the needle hope this makes sense. Quote
Northmount Posted December 27, 2015 Report Posted December 27, 2015 Thanks, I learned something new from your vid. Trying to explain. I have had some difficulty when sewing around the English point belt end. Your techniques showed me I can raise the feet BEDORE BURYING THE NEEDLE, giving me a view WHERE I AM, with the the need close checking the needle position, adjusting /moving the leather as needed, then set the needle hope this makes sense. Remember if you lift the foot too high, it will release your top tension. Otherwise, yes, it is very helpful when matching up corners, tight curves, etc. Tom Quote
Members paprhangr Posted December 27, 2015 Members Report Posted December 27, 2015 What I have been doing is bury the needle raise the pressure foot, take a look , start the Next stitch, using the reverse do a 1/2 stitch if needed moving the needle instead of the leather, which works But the technique above gives a clearer view of needle position Quote
Members gottaknow Posted December 28, 2015 Members Report Posted December 28, 2015 Nice job Uwe! Most of the upholstery shops I moonlight for use a 3/8" gauge double needle machine to do their French seams. To speed things up I solder a center guide on the foot to follow the seam exact. I then build a guide for whatever seam tape they use that holds it under the seam and feed the tape off a roll from under the machine. This eliminates the need to guide the tape or use adhesive tape. If you don't do a lot of this type of seam, a single needle with a 3/16" guide foot works well. The seam tape is a must imo. Regards, Eric Quote
Members TZBrown Posted January 1, 2016 Members Report Posted January 1, 2016 Very nice demo Uwe, Thanks for sharing Quote Life's A Journey It's not to arrive safely at the grave in a well preserved body, But rather to skid in sideways, totally worn out, shouting, Woo Hoo!....What a Ride! My Photos: https://www.flickr.com/photos/56844387@N04/sets/ My Videos: https://www.youtube.com/user/TZBrown01/videos
