Members FaitLaForce Posted February 29, 2016 Members Report Posted February 29, 2016 I'm looking for a bit of guidance on machine thread weights as they relate to different leather weights. I mostly do hand stitching, and really have no experience on what to buy for machine thread. What weight thread would you experts recommend for a lighter weight goat skin, and then a heavier veg tan? I don't rememebr the exact weight of the goat, but the veg is 2.3-2.7 mm. Thanks, and sorry if this is a repeat question! Quote
Members Dwight Posted February 29, 2016 Members Report Posted February 29, 2016 Depending on the "look" you want, . . . either 277 or 346 should do right well there. Your veg tan is in the 6/7 ounce category, . . . which I use a lot, . . . and my sewing machine is set up for 346 thread, . . . all my customers are happy with it so far. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Red Cent Posted March 1, 2016 Members Report Posted March 1, 2016 Dwight, what size needle are you using for the 346? Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Members Dwight Posted March 1, 2016 Members Report Posted March 1, 2016 Dwight, what size needle are you using for the 346? You would ask a 71 year old to read what is on that needle???? From what I can see with a 1 inch thick magnifying glass, . . . it looks like 200-25. When I had my machine in for repair, . . . they guy asked me if I needed needles, . . . he asked me the thread I was using, . . . that's what he gave me. They work in my Tippmann Boss. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members FaitLaForce Posted March 5, 2016 Author Members Report Posted March 5, 2016 Thanks so much for the help guys! I live in Haiti and do a lot of my sourcing in the Dominican Republic, and y'all helped me out at a clutch time. I was sitting in a show shop looking at a wall of thread, so confused. Went with the 277, and love it. Quote
Moderator Wizcrafts Posted March 16, 2016 Moderator Report Posted March 16, 2016 I use a #26 (Metric #220) leather point needle to sew with #346 thread, top and bottom. That needle opens a decent size hole for the large knots to fill. You can get by with a #25/200 needle if you use a smaller size in the bobbin (e.g.; #207, 277). The hole will be pretty tight with a #25 needle, which is why using smaller bobbin thread makes it easier to pull the knots up into the leather. While I mostly sew heavy stuff with #277 thread, when I use #346 on the top and bottom, it is usually in projects 1/4 inch thick and up. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Red Cent Posted March 16, 2016 Members Report Posted March 16, 2016 Tried the 346 top and 207 bottom with a 25 needle. I use 277 top and 207 bottom. Skipped stitches. Cobra 4. Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Moderator Wizcrafts Posted March 16, 2016 Moderator Report Posted March 16, 2016 Tried the 346 top and 207 bottom with a 25 needle. I use 277 top and 207 bottom. Skipped stitches. Cobra 4. It's safer to use a #26 Schmetz needle with #346 thread. You may need to increase the tension and lengthen the travel of the check spring to control the slack in that heavy of a thread. I normally run pretty strong tension on my check springs. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
