Members klaykrusher Posted May 8, 2016 Members Report Posted May 8, 2016 Sorry if this has been discussed before in a different section. I don't seem to be finding a lot of info. I've been searching for ideas on a DIY drying cabinet. Would like it to be long enough to handle belts and also roomy for holsters and other projects. Energy efficient too. I'm in the Midwest so solar may not work too well at least if the past few months of grey skys are any indication. I did see a few using incandescent lights, just looking for additional ideas (plastic container vs. wood, use insulation or don't, should have a fan to move air or not necessary, any extra ideas that you tried that worked or ended up not being worth it, etc.) before I move forward with the build. Pictures would be great if you have them. Thanks in advance..... Quote ~Dave
Members Halitech Posted May 8, 2016 Members Report Posted May 8, 2016 unless you are wet molding something and you want it hard, you don't want to use a lot of heat. You'd be better off using something with a fan to simply move the air around. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members TacticallySharp Posted May 8, 2016 Members Report Posted May 8, 2016 (edited) I always just use a fan even if wet molding, but I live in South Florida. Lots of heat and humidity here. Molding is done with a food bag vac system Edited May 8, 2016 by TacticallySharp Quote George Tactically Sharp, Inc. Hialeah, Florida tacticallysharp.com "time only is forever"
Members klaykrusher Posted May 9, 2016 Author Members Report Posted May 9, 2016 Thanks folks, yes I will be wet forming the holsters. To give you an idea the last one I just did took about 36 hours to dry. Inside temp was about 65-68. I'm not looking to speed dry the leather, just take it up into the 80 - 90 heat range to give it a boost. Quote ~Dave
Members silverwingit Posted May 9, 2016 Members Report Posted May 9, 2016 I am fortunate to live in Colorado for many reasons, one of them a very arid climate. I just leave my wet molded projects overnight and they are ready for me in the morning. Based on this experience, if I lived in a very humid climate I would make a drying box and put a smal dehumidifier in it. No heat, just dry air. Michelle http://www.amazon.com/Eva-dry-Edv-1100-Electric-Petite-Dehumidifier/dp/B000H0ZDD2/ref=sr_1_5?s=home-garden&ie=UTF8&qid=1462819040&sr=1-5 Quote
Members Colt W Knight Posted May 9, 2016 Members Report Posted May 9, 2016 Depending on the size of the box, a regular old light bulb will work to dry and circulate the air. Quote
Members OLDNSLOW Posted May 9, 2016 Members Report Posted May 9, 2016 My suggestion wouldn't work for a belt but would for a holster, get a food dehydrator and put the holster in it a for a period of time, and it might work for a belt depending on the size of the dehydrator. Quote
Members silverwingit Posted May 13, 2016 Members Report Posted May 13, 2016 My dehydrator gets too hot. It would curl and maybe even crack the edges of the leather. I wouldn't do it. Leather needs to dry out slowly. In general, heat is not good for untreated leather. Michelle Quote
