Thanks for the links.
My paper is yellow aluminum oxide roll - non adhesive.
Description here:
Siarexx 1960 rolls are c-weight / b-weight are professional products designed for hand & machine sanding in the woodworking industry. A stearate coating helps reduce clogging on the abrasive & prolonging the life of the product. Available from Grades P40 - P600, this product is a good all rounder for the woodworking & industrial maintenance. This product is also available in sheet, strip & disc form.
  • 2 weeks later...
Gorgeous!  Where did you buy the bonded leather for the inserts?  Is that available in the garment district too?
Also, may I ask what your favorite leather suppliers are?  I've only just started out, and I've been to Global a few times, but nowhere else yet.
Last question - do you crease the edges on your leather?  I'm trying to figure out whether that's something I want to pursue or not.
That is one awesome gift! How did you do the edges? They look fantastic!
  • 1 year later...
On 6/27/2016 at 0:42 PM, olenawills said:
Black Vernis 600 edge paint with electric heat tool.
Thanks for sharing your work. Can I ask what's the ideal temperature when using an electric heating tool?
  • 1 month later...
Sorry for late answer, but I don’t know the answer myself:)  Every Leather is different and I’m just trying every time on small piece. I have adice heating tool now and settings are changing all the time accordingly to the task. One handle for creasing is not that hot as another one , for edges.
