Moderator Wizcrafts Posted June 4, 2016 Moderator Report Posted June 4, 2016 I corrected my incorrect spelling of your last name, Darren. If you have the bobbins for a 42-5 and can sell them for the price range you mentioned, you'll have buyers on this forum. What woult the International Postage run on items like those? I am referring to the cylindrical bobbins, about an inch long. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Ken G Posted June 4, 2016 Members Report Posted June 4, 2016 Well son of a gun I didn't realise who Darren was. I was thinking the bobbins were about $3 each. The airmail shipping for my package was $13.00 for 12 of them and took about a week. They were lacking a thread hole but that is easily fixed with a little drill bit. 4 Quote
Members Cascabel Posted June 4, 2016 Members Report Posted June 4, 2016 (edited) I never had an issue with the 42-5 not releasing the tension, and I actually prefer this feature, as it allows sewing of anything I can fit under the foot, and causes no tension issues when climbing over thick seams. I have always just grabbed the thread below the take-up arm, and pulled out a few inches, and then simply removed the item after raising the foot. I also just use ordinary 135x16 and 135x17 needles in mine. I don't know if my machine was adjusted for these common needles by the previous owner or not. but I suspect so, or maybe adjustment was not needed. I was able to get spare bobbins from my local industrial machine supplier, with no problem. I think the bobbins are common to several different machines. Edited June 4, 2016 by Cascabel Quote
Members Darren Brosowski Posted June 5, 2016 Members Report Posted June 5, 2016 Sorry Wiz, I was flicking through and did not properly read your post until after I put mine up. I do not mind the spelling of my name as long as people can find me!!!! I am putting together an order with my Taiwanese supplier so I will add some 42-5 bobbins. If people want them then please PM me to give me an idea as they are a slow mover and I normally only get 50 at a time. Quote
Members Hilltop Posted June 7, 2016 Author Members Report Posted June 7, 2016 I hope I am not to late to pm you about the bobbins! Sending you a message right now. Weren't you the member here that was going to make some needleplates? I got my machine to sew 4.5 stitches an inch after realizing I adjusted the feed dogs when I had my gigantic more aggresive ones mounted on the machine. I will post a picture later tonight. Does anyone else here have a double set of feed dogs on their machine? Most pictures I have seen online have been with a smaller feed dog set. Quote
Members Nix Posted June 8, 2016 Members Report Posted June 8, 2016 I have that big double set of feed dogs -- it's like two parallel sets of long feed dogs (part no. 5840 in the book) -- for mine. However, I'm lacking a correct needle plate that you need to go with it. The corresponding needle plate would be part no. 5881. Is that set-up designed to produce fewer stitches per inch or a better feeding of goods, or both? Nix Quote
Members Savvas Posted May 3, 2020 Members Report Posted May 3, 2020 On 6/3/2016 at 11:51 AM, Uwe said: "I have a Singer 42-5 that's patiently awaiting its turn for some tender loving care. Parts are hit and miss. Needle bar and presser spring were readily available and cheap..." Hi Uwe, I have a 42-5 - I would be grateful if you could remember where you obtained your new needle bar for yours please - mine appears to be bent. Many thanks, Sam, Adelaide, Australia. Quote
Members Bert51 Posted May 4, 2020 Members Report Posted May 4, 2020 Sam, this post is over 4 years old, I think you would be better to start a new post, rather then try to use something this old. Bert. PS. Did you get your manuals? Quote
CowboyBob Posted May 4, 2020 Report Posted May 4, 2020 On 5/3/2020 at 2:44 AM, Savvas said: The 42-5 needle bar is the same as a 16-188,41 & etc machine part #4264,there should be some on Ebay. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Savvas Posted May 7, 2020 Members Report Posted May 7, 2020 On 5/5/2020 at 1:24 AM, CowboyBob said: The 42-5 needle bar is the same as a 16-188,41 & etc machine part #4264,there should be some on Ebay. Thanks Cowboy - the part number is much appreciated! Sam Quote
