RockyAussie Posted September 24, 2016 Author Report Posted September 24, 2016 It is a high density polyethylene as shown in following link. Could not spell it like a lot of things so looked it up and found this. http://www.usplastic.com/catalog/item.aspx?itemid=23751&catid=705 I first starting using this type of material years ago when I made shoe orthotics and such. Due to it being thermo mouldable I found it to also be useful in casting outer shells for leather moulding cases and such.Being a slippery type of surface it is great for repetitive work leaving no scratches and marks etc. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members msdeluca Posted September 24, 2016 Members Report Posted September 24, 2016 (edited) That is fairly close to the set-up I came up with. I like your addition of the hinge point and index line. I just clamp mine since I'm only doing a few shoulders at a time. I've also been having good success with a 60mm rotary cutter rather than a head or utility knife. No need to do a scribe cut; just clamp the straightedge and cut the leather... usually two passes in 8 oz. veg tan. Also found a good source for poly in the US that sells remnants cut to your size request (if they have a piece large enough). More info link Edited September 24, 2016 by msdeluca Quote Michael www.conceptleather.blogspot.com www.temptedthreads@blogspot.com
Members plinkercases Posted September 24, 2016 Members Report Posted September 24, 2016 Thank for the board info. That is what I have sourced here in Toronto so I am on the right track. I do envy the space you both seem to have to work in though... and hey Aussie I just notices your helper hound in the picture. Nice, addition to a shop for sure. Quote "Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691 plinkercases.ca
Members brmax Posted September 25, 2016 Members Report Posted September 25, 2016 (edited) Rocky that is sure to be some production work as I see it, and say the little time I have had one " a rotary knife olfa" is pretty sharp Just wanted to be curious with any information you have, as to using one for this work because it would sure give a time and durability test result. Floyd Edited September 25, 2016 by brmax Quote
RockyAussie Posted September 25, 2016 Author Report Posted September 25, 2016 Hi Floyd, I would be interested myself but the cutting part per shoulder would be only about 30 seconds per sheet if I take out the handling on and off the table and lining up etc. It actually took one of my staff longer to unwrap them and lay them on a table then the cutting part of the job.The beauty of the round knife is that I only needed to polish on a rag wheel with Tripoli twice on this lot. I am always looking for easier and quicker ways but I am dubious whether the rotary knife would work long term wise. I did get a Good improvement on time on the next step today by changing the strap cutters motor pulley from a 2 1/2" up to a 4".This gave a 60% quicker cutting time. . I have also changed the speed setting on the splitter and so far is going well but unfortunately I figga I still got maybe another 3 or so hours there to go. Be a lot better if it wasn't for my main competitor in the belt area.(love these little faces) Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
