1 hour ago, Art said:
So good of you to volunteer to give this a try for us.  Please let us know how it works out for you.
Art
Haha. I'll give it a shot....I'll look and see where I saw this. It was some older website I think and it was referring to using dye in those little spray gun things. I'm really new to leatherworking, so forgive my ignorance here. :-)
Thanks!
Chris McCollum, firearms & LTC instructor
Texas, USA
  • Replies 29
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
9 hours ago, Dwight said:
Biker, . . . in times past I messed around a bit with some of those ratios.
It will look good for a year or two, . . . then it will change.  In most cases it seems to get lighter and drifts off to a more "sunburned leather" color.
I know where there is a beautiful single holster, . . . plain western rig that was almost a funky dark grey when it was done several years ago, . . . and now it was drifted down to a medium dark brown.  Don't get me wrong, . . . it still is really good looking, . . . but the color has changed significantly.
That has been my experience with the lighter ratios, . . .
May God bless,
Dwight
I don't have any experience with it yet, I just read it is all.
Thanks for the heads up.
Being a hobbyist I wouldn't be too worried about colors changing over the years. But if I ever go retail, I will have a good disclaimer to work into the deal.
Disclamer: I have only been doing leather work as a hobby for about 9 Months, so take my words with a grain of salt.
I've been using good old 91% Isopropyl alcohol for diluting as I always have a ton of that stuff around here. I always dilute my spirit dyes at least 50%. Usually the ratios are more like 1-2 or 1-4 dye to alcohol. These days, I try to be somewhat methodical with how I work with dyes. I write down exactly what I did to get what color on what item, and with what leather. Every hide of leather is different, so you should always want to try out whatever you're doing on a small piece first. From talking with several people, everyone seems to have their own way of doing these things. Not sure if any particular way is "right". Usually the advice that most people have given me, is find something that works for me to get the look I want and just keep doing that.
Thanks Flux41! GOod advice. Especially the keep copious notes part... I think I'll start doing that as well. I'm very new to this. I've been making little draw string sacks for years with my dad...but always with same exact type of suede and in the same pattern. So I'm basically starting from square one. So each little project i do is basically a little project full of small mistakes. Each one a learning opportunity.  I'll get better over time fast by taking notes.
Thanks!
Texas, USA
  • 2 weeks later...
Or you can take the advice of people who have been doing it for years and have already made the mistakes. Will jump start your progress exponentially.
I agree with Dwight on this one, mix about 50/50 with denatured alcohol. The DA is relatively cheap and anything more then a 50/50 split gets into the area of repeated coats  to get a good color.
Denatured alcohol, also called methylated spirits or denatured rectified spirit, is ethanol that has additives to make it poisonous, bad tasting, foul smelling or nauseating, to discourage recreational consumption. In some cases it is also dyed.
Denaturing alcohol does not chemically alter the ethanol molecule. Rather, the ethanol is mixed with other chemicals to form an undrinkable solution. For many of these solutions, there is no practical way to separate the components.
https://en.wikipedia.org/wiki/Denatured_alcohol
I use the cheaper stuff and don't see any difference. Then again, I don't use deglazer either.
So, for us non-techie folk, meths will be ok for diluting the dye?
(Sorry, but I alway read about denatured alcohol, and such stuff, etc, and I hear a little 'whoosh' as the words go over my head.)
“Equality?   Political correctness gone mad, I tell you, gone mad!!!!    Next they'll be wanting the vote!!!!! :crazy:“.
Anger and intolerance are the enemy of correct understanding
Here is something to add. I have a hide from Tandy that just won't evenly take diluted dye of any mixture.
I was using fiebings mahogany. It continued to come out putrid variations of purple with darker specs all over it.
I had this same result with daubers, sponges, and dip dyeing. I finally had to resort to full strength.
This left me with a black piece with a hint of purple.
So, take note of the leather you are using. Cheap leather can leave you blaming the dye or technique, when you should really be addressing the material.
Just a heads up.
Thanks.
