Members oxeyenyc Posted August 25, 2016 Members Report Posted August 25, 2016 Hello Leatherworkers! From Pilgram Sewing Supply I bought the parts to convert my 31-15 to a roller foot (S-194 Foot bar, needle plate and feed dog). The roller foot on the new foot bar is small (and doesn't swing open to the side), so I went to my local sewing machine repair shop and picked up a larger roller foot, which does swing open. When I brought the larger roller foot home, I noticed that it doesn't seem to be compatible with the foot bar...is there something that I am not seeing? Or is this new awesome big swivel roller foot not the right one for a 31-15? Thank you kindly for your input! Please see photos below (the larger swivel roller foot is pictured to the left, the smaller roller foot that came with the foot bar is to the right). All the best, Dana P. Quote
Moderator Wizcrafts Posted August 25, 2016 Moderator Report Posted August 25, 2016 Remove your small roller foot and take it and the unusable large roller back to where you bought it. Ask for a large roller that has the same mounting bracket as the small one that does fit. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members oxeyenyc Posted August 25, 2016 Author Members Report Posted August 25, 2016 Hi Wiz! Thanks so much for the reply! The more I am looking at this, I am thinking that the new S-194 foot bar from Pligrim is unnecessary...I look at the foot bar that is already on the machine, and it seems to match up to the mounting bracket on the big roller wheel. I've attached a few pics (of the current foot bar and big roller foot) if you don't mind to take a look--I am trying to follow your instructions (below), but am having some trouble removing the screws so I've oiled em up and am waiting to give it another go! Also, would you mind to tell me your opinion on the feed dog/plate combo that Pilgrim sent me? The length of the feed dog seems small for the plate, but maybe it is ok? I used to use a Consew 225 walking foot and just switched over to the 31-15...I'll be using it to stitch cowboy boot uppers! Thanks again! Really appreciate all of the shared wisdom Quote
Members oxeyenyc Posted August 25, 2016 Author Members Report Posted August 25, 2016 Success getting the large roller onto the existing foot bar! So hopefully this thread might be useful to anyone who is looking to switch to a roller foot--you don't need to buy an entire new foot bar, even if someone on the other end of the phone tries to sell you one! Now the only issue I am having is that I got the foot bar to move up (by loosening the screw and then loosening the screw on top of the machine...)but now it won't go back down! I think I maybe loosened too far? (sorry for such a long thread, y'all Quote
Uwe Posted August 26, 2016 Report Posted August 26, 2016 The Singer 31-15 was not really designed to accommodate any roller feet, it seems. At least the parts manual for the Singer 31-15 doesn't show any roller feet options. Sometimes you get lucky and a part designed for another machine fits and actually works. I'm guessing that your big roller foot ends up being much taller than a regular foot, and the standard presser bar does not have enough of an adjustment range to accommodate the big roller foot. You may be out of luck making the big roller foot work with your existing presser bar, even though you can mount the roller foot. Perhaps that is also why the original roller foot you bought came with a special presser bar to make it work. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members oxeyenyc Posted August 26, 2016 Author Members Report Posted August 26, 2016 Hi Uwe! Thank you for including the link to the parts manual, that is pretty cool! I was just able to make the final adjustment to use the original bar and the big roller--I completely removed the screw on the top of the machine and this allowed the bar to move up and down freely. Now I just need to ask my neighbor to borrow his ratchet screwdriver in order to remove that back screw on the presser plate! What a poor placement for that screw Quote
Members oxeyenyc Posted August 26, 2016 Author Members Report Posted August 26, 2016 oh boy...what an evening of trying to figure this out I thought I should make one final update to this post, for anyone who comes across it in the future! It turns out that the big wheel was too big to be adjusted close enough to the needle...so in the end, the kit with the small wheel seems like it is the way to go! Thanks to everyone who weighed in! Quote
Members dikman Posted August 26, 2016 Members Report Posted August 26, 2016 Co-incidentally I just this morning fitted my roller foot to the Singer 331K4. The foot assembly appears to be identical to yours (except it's black so probably goes faster ). The hardest part was getting the foot bar out so that I could clean off the buildup of grunge on the bar - all these other bits fell out when I removed it! Took a bit of tweaking to get it adjusted right but looks like it should work ok. The feed dog and needle plate look the same as yours too. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members cdthayer Posted August 26, 2016 Members Report Posted August 26, 2016 I have roller foot #12264, needle plate #5709, and feed dog #5708 on my 1939 Singer 31-15, and it works just fine. I made no changes to the presser bar position. For what it’s worth: I had a problem putting the same combination on my 1936 Singer 96-40 machine, and finally determined that the after-market lower thread guide (on the needle bar) stuck out and interfered with adjusting the roller to the dog. Since then, I’ve turned the 96-40 into a darning machine with a different Ft/NP/FD combination on it, but now know why I was having problems with the roller. CD in Oklahoma Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Members oxeyenyc Posted August 26, 2016 Author Members Report Posted August 26, 2016 It has been great to see and hear about how everyone approaches their roller foot conversions on the 31-15...in the end I brought the big wheel back over to the sewing machine shop and he ground down the edge of the bracket (the wheel touched the bracket otherwise when adjusted close to the needle). So I ended up with the original flat foot bar, the big roller wheel, and the new feed dog/plate (part numbers 12836 and 12838). I sent back the new footbar/small wheel combo (the wheel didn't swivel to the side which kinda bummed me out!...part number S-194, if anyone in the future might find this of interest Thank you everyone for sharing all of your insights and photos! Quote
