Yep, nice looking machine. Looks very much like a 111 head dropped onto a cylinder arm base. I like it.
As Mike said, it would probably be easier to just paint the base, if you can find a close match to the paint.
  • Replies 130
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Not sure what Ill do with the paint, been lucky so far in that most machines Ive gotten the paint was pretty good just needed a cleaning. Ill go thru it mechanically and see how things are on the inside. Hopefully it isnt too wore out to start helping put together some bags.
The guy I got it from said that he purchased another machine (some post bed old singer model) from a guy who worked at a glove factory in Pennsylvania somewhere and this machine was sitting in the room a little ways away. The guy said it hadnt been used in years and they didnt need it so it was bought along with the other machine. Or so the story goes.
Figure an old glove making factory could use machines like this back in the day. Maybe they ordered it with some special attachment to help with glove making. If the story even has some factual truth to it that is.
Edited by MADMAX22
Perhaps "SV" stood for "Stolen Version" since they later became regular subclasses :)  Can't see anything SPECIAL with them.
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
I have had a few SV machines over the years and most were early versions of machines that later became standard while others were standard machines with a special attachment.
24KSV - I have it around somewhere - is a standard industrial 24k with an attachment to sew circles. The attachment was designed to sew Powder Puffs.I am going to dig this baby out as a close friend has a design that involves making circles
96KSV7 - 96k with reverse, replaced by the 96k41
133KSV12 - darning machine. Quite common in Australia as they were used to repair wool packs. Later formalised as, I think, the 133k19
Serial numbers.
Singer issued serial numbers of batches so they do not specify the build date. The machine was built sometime between when the batch was issued and the next batch for that machine type.
Usually batches for common machine types such as the 31 would have covered multiple versions as the serial number is just for the class.
Every now and then there are batches of serial numbers for 10 or 20 machines and these could represent SV's or a special rush order from sales - we will never know.
So given what everyone has contributed my machine is up in the air.
It was originally all black which I "think" was primarily older machines in the 153w world, it has similarities to the WWII era machines but cant prove it, but it also has a machined notch on the front with two tapped holes for some kind of attachment I presume.
So basically it could have been a special attachment machine or it could have been the predecessor to the regular 153w103.
Darren, thanks for the comment on the serial numbers, all good info.
  • 1 month later...
Hi again, i have found an interesting list of sv machines but it is in pdf, how can i upload it here??
Singer Needles by Machine Class chart.pdf
Edited by northmount
uploaded file
Thanks Tom for uploading.
Here is a list of machines and varieties of the various classes, which states its needle type, and the SV models are included. so you can get an idea of just how many there were!!. it does not list all of them. as you can see it says for example "for all sv models except......." but it does not give the list of all these models. but anyway it is a little bit closer to finding out a bit more about the SV models. Enjoy!
A guy on ebay had a W serial number machine listed with date of manufacture. I asked him how he determined the date and he said there were some list of W serial numbers out there that were not destroyed. Ofcourse when I asked if he could share the info he never responded :rolleyes:
Thanks for the list Jimi.
