Members AEMcClain Posted August 31, 2016 Members Report Posted August 31, 2016 So I took the leap and bought a clicker press, and now I am weighing my options as to how to hook it up. From what I can tell I have three options rotary converter, static converter, and VFD. I am leaning toward the VFD because it will be the only piece of machinery requiring a phase converter in the foresee able future. I thought I would pose the question here and see what you all do. Quote
Members Seaboard Posted August 31, 2016 Members Report Posted August 31, 2016 Go with a VFD and it just needs to be sized to the next largest HP to cover the amp draw in the single phase conversion. Generally you would use a 7-1/2 HP drive on a 5 HP motor. Also depending on the HP of the clicker press motor you may be able to get away with using 110V input instead of 220V, but the later is better. Most of the VFD's sold now have all kinds of pre-programmed crap in them that you don't need but just stick to one that is able to do the single phase power in. You may want to check out the full load amps because they vary a bit between manufactures. Yaskawa makes a really nice one that is rated for higher amps but Square D has some simple ones as well as Lentz, Toshiba, etc. Hope that helps. Chris Quote
Members AEMcClain Posted August 31, 2016 Author Members Report Posted August 31, 2016 Thank you, that is the direction I am leaning. Quote
CowboyBob Posted September 1, 2016 Report Posted September 1, 2016 Since there's no electronics involved a simple one is real easy to make.I made one for our Bridgeport mill yrs ago & it still is working.All you need is an old 3 ph motor large than your motor ,run 2-110 v separate lines to it & continue on the the clicker motor.Then we hooked up a starter motor that spins the convertor motor.So we get the starter motor spinning first ,then turn the 220 on ,shut the starter off & the 220v convertor motor keeps running & as it runs it puts out the 3 phase.This does only work w/Deltawound motors(for the convertor).But the spare motor we had laying around just happened to work after we got it wired up. PS. I did try a static convertor w/condenser in it & had some much power loss it wouldn't work,did an online search about convertors & found out about this. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Mark842 Posted September 4, 2016 Report Posted September 4, 2016 I run a rotary phase converter but I also run other 3 phase equipment. Have no idea which is better as I have no experience with a VFD. Looked at them when I bought my phase converter and it seemed like they do a lot more than I need and I'm familiar with Rotary converters and new I could install on my own. Quote
Members GPaudler Posted September 4, 2016 Members Report Posted September 4, 2016 Go with a VFD. They are easy to set-up and reliable and you can find them cheap on eBay. They can be used to control speed and programmed for soft start. In a one-person shop where only one machine is likely to be running at any time, you can have a single VFD with an outlet into which you can plug any machine. Quote
Members AEMcClain Posted September 4, 2016 Author Members Report Posted September 4, 2016 I think I am going to go with a vfd. The electric motor on the clicker is a 1 hp 3.2 amps at 220 3 phase. From what I can find The 120 single phase to 220 3 phase vfd rated at 4.0 amps will handle the motor at full load and have some margin for safety. Here is the one I am looking at WEG VFD . According to what I have read this vfd does not need to be de-rated as long as the operating temp is below 122 degrees. Quote
Trox Posted September 15, 2016 Report Posted September 15, 2016 On Sunday, September 04, 2016 at 4:05 PM, AEMcClain said: I think I am going to go with a vfd. The electric motor on the clicker is a 1 hp 3.2 amps at 220 3 phase. From what I can find The 120 single phase to 220 3 phase vfd rated at 4.0 amps will handle the motor at full load and have some margin for safety. Here is the one I am looking at WEG VFD . According to what I have read this vfd does not need to be de-rated as long as the operating temp is below 122 degrees. I use such frequency controllers (drives) all the time, sine I do not have 3 phase current in my workshop. Here (Norway) its 220v on single and 380v on 3 phase but the principals are the same. I use the drives on solutions when I need to control the speed on the motor (in addition to convert the current). On my clicking machine I rewired the motor to have it running on single Ph. I used two big 70 micro Farad capacitors not to loose any staring up torque, it is as strong now as it was before running on 3 Ph. You can loose a little torque when you use these drives and on some frequencies they tend to make bad sounds. That's no problem when you can adjust the speed, just change the speed/Hertz and the sound dissappear. On a clicking machine you have to run on maximum speed/Hertz all the time, you just have to hope it will not sound bad on that frequency. Here is an other AC motor (1,2 Kw 3 Ph) I had wired for the single Ph current. This is a air compressor motor but of similar size as the clicking machine, wired exactly the same way. Sorry for the bad picture quality, I can take new pictures if you are interested. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members Nuttish Posted October 30, 2016 Members Report Posted October 30, 2016 You can get a used single phase 1HP Baldor or Dayton for less than 150 and avoid the ~1/3 power loss you'll see with a VFD. Quote
Members dikman Posted November 4, 2016 Members Report Posted November 4, 2016 I guess it all depends whether variable speed is required. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
