I'm looking for a cheap air brush, does anyone have any ideas what I should get and where is a good place to get one (harbor frieght?). I have never used one and am looking for some ideas. thanks
The HF will work ok I bought 2 of them, and one that came direct from china that is a recommendation from a thread here on the site.  I do like the one that came from china direct a little more than the one from HF, I also bought one of the compressors that has like a 3 gallon tank from HF.  Between all of it they have come in handy, I have used them more for some two tone belts that I make more than anything else, I really should use them more for holster work.  Help this helps but also look for the thread about airbrushing here, the search button should help or someone else I am sure will comment.
ya that's true if ya got the bucks to buy with! I guess you could get yerself a 40 percent off coupon for hobbie lobbie and buy there.
6 hours ago, Roq said:
Buy once cry once, get a Paasche or Iawata.
Depends on the level of detail you need to be able to do.  Just general overal dye job doesn't need fancy setup artists use for drawing/painting fancy art.  Have a new Iawata in the drawer I have never used in the past 4 years.
Tom
Tom
My post was about the quality of the airbrush not detail work. You can get an Iawata around $55 usd and it will last a lifetime.
I've used a paasche vl for quite a while.  Get the entire set for about $60 ... including the cup, the hose, blahblahblah.. everything but the compressor.  Basically indestructible.. lasts forever and sprays everything from dye to top coats. Simple use and clean-up.
Each his own, but I don't see teh 'value' in saving $20 to get something that's basicaly a pain in the back to use.
5 leather patterns
Great info, thank you all for the imput. I'm just thinking about starting with it, so i don't want to get frustrated with a POS, so may spend a little more money.
the only thing I will suggest is that you buy a compressor with a tank and a replaceable water filter. The tankless ones will not give you the constant pressure you will want for spraying and if you are using non-water based dyes and finishes, you won't want moisture in the air line
Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
