nushearman
What Stands work best for belts...
Hello All,
I've started doing more shows and fairs and I always struggle with displaying my belts... I was wondering if anyone had any stands that they use and rely on... something that makes it easy for customers to select the items they can hang and look nice.
All help welcome!!
Thank you
Nu
A nice old trees stump with the belts hung on hooks would look great, or a nice display cabinet similar to this one but better, done with some nice oak or pine board, with some nice antique brass hooks
Hi Nu, Here if it helps is a bag Hanger that I came up with a fair while ago. I have attached a pdf file that if printed on A4 should be true to size. The main advantage with this is it can allow the belt to be taken on and off a long run of belts without taking the holder off. The size marking on it helps to keep the belts to go back in the right order as well. I normally supply these to my customers a range of for a around a couple of $ each. Between 2 and 3mm Veg works well. Also there is a bit of room for your logo as well. The last picture shows what you can do with an old shopping trolley as shown here welded to my garage door. Regards Brian
Belt hangerl (2).pdf
