Members Steve75 Posted November 1, 2016 Members Report Posted November 1, 2016 My niece is showing cattle for 4H. I have been searching in vein for a pattern to make her a halter. Tandy has a pattern pack but its for horses. Anyone know where I might be able to find a pattern to make one? Below is a picture of what I am talking about. Any help is appreciated. Quote Steve "No man is above the law and no man is below it; nor do we ask any man's permission when we ask him to obey it." Theodore Roosevelt
Contributing Member Ferg Posted November 1, 2016 Contributing Member Report Posted November 1, 2016 I use photos of product, mostly old, to get an idea of how things are made. I then do some measuring of the subject, make a heavy paper prototype and go from there. Ferg Quote
Members rejerome Posted November 1, 2016 Members Report Posted November 1, 2016 Like Ferg, I use photos. I have some photos with a ruler next to the parts that I'd be happy to send to you. Rex Quote
Members fivewayswelshcobs Posted November 1, 2016 Members Report Posted November 1, 2016 There probably aren't many patterns out there but to get the size put a rope halter on and position it where you want then stick tape on the length of the nose and the head strap then make an allowance for the rings ,ie use the radius of the ring not diameter. If doing the rolled halter then add enough leather to the ends of the nose so it will fold around the ring and allow about 1 inch for stitching and another inch feathered down to nothing to tuck in the start of the rounding, repeat at other end. The width would depend on the size of the animal so for a cow 1 inch or more but for a calf proportionally narrower. On the head strap do this to the ends of the strap (work it out on paper) then add around 2 1/2" to the allow for the buckle return and feed into the rounding after deciding the position of the buckle, for the point strap add 2" +the space you want the holes to be apart eg 3/4" between holes add 11/2" to give you the centre hole, if measured accurately can reduce to 3 holes to shorten the point end but this can limit the animals it can be used on. I assume from the style it is a dairy heifer as this style is not strong enough for beef animals. I hope this helps. Quote
Members Steve75 Posted November 1, 2016 Author Members Report Posted November 1, 2016 On 11/1/2016 at 2:51 PM, rejerome said: Like Ferg, I use photos. I have some photos with a ruler next to the parts that I'd be happy to send to you. Rex Expand Rex, Thanks, that would be great. On 11/1/2016 at 2:37 PM, Ferg said: I use photos of product, mostly old, to get an idea of how things are made. I then do some measuring of the subject, make a heavy paper prototype and go from there. Ferg Expand Ferg, Thanks, for the advice. The photos will be a great source for ideas on hardware to use in building the halter. On 11/1/2016 at 2:51 PM, fivewayswelshcobs said: There probably aren't many patterns out there but to get the size put a rope halter on and position it where you want then stick tape on the length of the nose and the head strap then make an allowance for the rings ,ie use the radius of the ring not diameter. If doing the rolled halter then add enough leather to the ends of the nose so it will fold around the ring and allow about 1 inch for stitching and another inch feathered down to nothing to tuck in the start of the rounding, repeat at other end. The width would depend on the size of the animal so for a cow 1 inch or more but for a calf proportionally narrower. On the head strap do this to the ends of the strap (work it out on paper) then add around 2 1/2" to the allow for the buckle return and feed into the rounding after deciding the position of the buckle, for the point strap add 2" +the space you want the holes to be apart eg 3/4" between holes add 11/2" to give you the centre hole, if measured accurately can reduce to 3 holes to shorten the point end but this can limit the animals it can be used on. I assume from the style it is a dairy heifer as this style is not strong enough for beef animals. I hope this helps. Expand fivewayswelshcobs, Thank you for sharing the measurements and advice on construction. I enjoy visiting this website as I am able to get sage advice from experienced leatherworkers. When I have the halter made I will post pictures of it. Thanks again for your advice guys. Steve Quote Steve "No man is above the law and no man is below it; nor do we ask any man's permission when we ask him to obey it." Theodore Roosevelt
