Contributing Member JLSleather Posted December 21, 2016 Contributing Member Report Posted December 21, 2016 (edited) I just dip mine in water. Kaint afford that fancy spray bottle stuff Still, that spray seemed to work ... Edited December 21, 2016 by JLSleather Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Bolt Vanderhuge Posted December 21, 2016 Author Members Report Posted December 21, 2016 I just dip mine in water. Kaint afford that fancy spray bottle stuff Still, that spray seemed to work ... Haha Quote
Members Bolt Vanderhuge Posted December 21, 2016 Author Members Report Posted December 21, 2016 Still trying to figure this site out I was using my phone and once I typed the Haha I could not move the cursor back to change what I was typing so I closed the browser yet it still posted it. HMMMMMMMMMMM. I was wanting to respond though. The laughing was intended. But I wanted to insert a smiley instead . I also wanted to say add that I used to get the leather saturated with water by either dipping or moving under the running faucet. But I never had the patience to wait for the leather to get to the proper state of casing before working it. This just caused a lot of extra work in both mistakes and lack of satisfaction with the level of detail. This spray technique has worked well for the last few holsters and is allowing me to get the practice I have needed in correctly working leather to the shape and level of detail that I have been looking for. I have a few new pics but I have to run off to work for an quick meeting. I will post them up shortly Quote
Members Bolt Vanderhuge Posted December 22, 2016 Author Members Report Posted December 22, 2016 (edited) Here they are. It was starting to rain almost immediately when I set up outside so I had to use my phone again and get whatever I could get. You can see a few rain sprinkles in a couple of the pics. I wanted to get a couple pics that show that the lower backside screw does not go thru to the front of the holster and the upper front snap also does not go thru to the back of the holster. I used T-nuts that I got from Holsterkits.com. I made channels for them on the inside between the two layers of leather to keep them from turning so that all hardware can be removed if needed. Edited December 22, 2016 by Bolt Vanderhuge Quote
Members YinTx Posted December 22, 2016 Members Report Posted December 22, 2016 Those edges tho! Nice work all around, I really like it... YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members lansacoder Posted December 22, 2016 Members Report Posted December 22, 2016 Beautiful holster! My only thought is that it might be possible to embed the t-nuts in the back of the belt loop so the only screws would be inside the snaps and the loop would still be removable as you had wanted. Thanks, Bob Quote
Members Bolt Vanderhuge Posted December 22, 2016 Author Members Report Posted December 22, 2016 (edited) 1 hour ago, lansacoder said: Beautiful holster! My only thought is that it might be possible to embed the t-nuts in the back of the belt loop so the only screws would be inside the snaps and the loop would still be removable as you had wanted. Thanks, Bob While the t-nut locations are secure they are no where near as strong as the thru-hole location in the middle. So for longevity sake of the holster, having thru hole mounting is for the best. But that does not need to be used for each location. At least that is my story and I am sticking to it . Honestly, I did think about hiding everything but the snaps themselves like what you are suggesting. But the thru-hole has strengths that the t-nut cannot match and chose to use it to it's full potential for defining the belt tunnel and holding things together with the most strength possible. Also the lower belt strap screw is not shared with either snap and the upper snap is located at roughly the middle of the belt so the lower strap screw still would have to go thru either the front of the holster or the strap itself like it does currently. For any one wondering, here are descriptions with pics to show the snap and mounting locations. The upper snap is up near the top of the holster and the belt runs directly behind it (see the red locations in pics). The lower snap goes thru the holster and the belt strap to define the bottom of the belt tunnel (see the blue locations in pics). The lower belt strap mounting screw is below that point on the holster (see the yellow locations in pics). Edited December 22, 2016 by Bolt Vanderhuge Quote
Members lansacoder Posted December 22, 2016 Members Report Posted December 22, 2016 That makes a lot of sense. Now that you explained that, I can see where hiding the screws would either create a weak loop or a loose belt loop, depending on the placement of snaps. Nice work and well thought out. I've been wanting to make one of these for myself. Thanks for the advice. Quote
Members Bolt Vanderhuge Posted December 22, 2016 Author Members Report Posted December 22, 2016 You can use furniture type tee nuts as well. With their spike tabs they do not need material removed to get them to not turn, But this comes at a price. They are wider then what I used and in tight areas they may not fit between stitch lines. They both have the possibility of being over tightened and loosing their ability to stay in one place. This is another place where thru-hole has an advantage. A thru-hole setup can be cranked down without fear. You then have to decide open or closed back. The closed back does not offer a flathead or allen wrench method of holding it in position while you tighten or loosen the front side. Quote
Members Popo425 Posted December 23, 2016 Members Report Posted December 23, 2016 Great job all around! Quote
