alexitbe Posted October 15, 2017 Report Posted October 15, 2017 Thanks Constab.... So if it is screw 25 it must means changing the stop position? Quote
Members Constabulary Posted October 15, 2017 Members Report Posted October 15, 2017 The 25 screw is just for fixing the position of the disc #24 - I have the screw centered in the oval slot (so it is shown in the manual) - never had an issue with this position. Other tension units - f.i. Pfaff 145 and the like - do not have this screw. The disc at Pfaff tension units is held in position by just a pin so its not adjustable. So on Singer type tension units you "could" adjust the position of where the thread pops over the hook tip when threading the machine but being honest I never thought of changing this position or playing with it. If I had to change the travel of the regulating spring I´d do it on the curved piece #27 (on either Pfaff and Singer). But maybe there is an explanation for the slot in the disc 24 - yet I have not figured its purpose but that does no mean anything. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted October 15, 2017 Moderator Report Posted October 15, 2017 I have a long body Singer walking foot machine that has been retro-fitted with a Juki LU hook. Despite being as timed as it can be, top to bottom shafts, the top thread still tends to snap on the way around the bobbin and shuttle. I am able to alleviate this by rotating disk #24 to the right, after loosening screw #25. The far right position feeds more slack thread into the shuttle and compensates for the much larger diameter hook that was over-stressing the thread. Unmodified machines rarely need to have the disk moved from dead center in the slot. But, one can use this adjustment to fine tune how much slack thread is fed to the shuttle on the downstroke. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
alexitbe Posted October 16, 2017 Report Posted October 16, 2017 Thank you everyone... I see that I am going to have to have a close look at one of my old machines and see what difference rotating disk 24 makes... I think the spring rests on it and thus that is why I thought it changed the stop position of the spring... However, now I am not sure... Cheers Alex Quote
Members Constabulary Posted October 16, 2017 Members Report Posted October 16, 2017 curved piece #27 is where the spring rests on. It is mounted with 1 screw (Singer manual picture screw "P") - loosen the screw and you can adjust the spring travel Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members ke6cvh Posted July 9, 2019 Members Report Posted July 9, 2019 This is an amazing thread that I appreciate very much for it' s information. I can see these tension assemblies for the Singer 111w through Consew 206RB on eBay for just under 10 US dollars. I am planning to install one of these on a cheap Chinese leather patcher (we actually have 4 different types with one of them being a clone of a Singer 29k72, one being the tiny one people many times buy, one being a heavy hitter rc32-3a taking up to nm250 and max 3.5cm thick/min essentially zero thick, one being a post bed rc32-2a with same bobbin as the large version of the 29k patchers). I see lots of people on this facebook group for patchers install aftermarket tension assemblies but they are always removing the check spring. The 29k72 clone has a leaf spring on the take up lever that is adjustable but my suspicion is that it is a crude and inferior version of a check spring. The other three low cost patchers only have a spring on the take up lever. My suspicion is that everyone who is experiencing stitches with upper loops occasionally are having one of two issues. One is the known issue of allowing the hand crank to go backwards even a tiny amount during a cycle. The other likely is a crude or completely missing check spring assembly. We are installing diy pulley reducers and 750 w BLDC motors with a total reduction of around 6:1 in speed. We want good control not so much the power available from the motor as we'll be sewing very slow on them. With the pulley reduction and servo the backwards motion is a non issue. I prefer Bob's brushed DC motors but these do have an advantage in that there is no brake pads. If I'm going slow anyways I don't think I need the brake pads anyways (and the motors were easily available with same pulley shaft as clutch motors allowing me to change to different sizes). My suspicion is that this information, coupled with the assembly same as one in Uwe's video and discussion will vastly improve quality of stitching (when properly adjusted). Best regards and many thanks for contributors on this thread, Mike Quote
Members Gymnast Posted July 24, 2021 Members Report Posted July 24, 2021 (edited) On 1/2/2017 at 6:54 AM, gottaknow said: Once you get the stop set to ensure the thread is still taught as the needle enters the material, the torsion of the spring should corespond with the needle thread tension. The tighter your needle tension, the more check spring torsion. Sometimes you can find a happy place and it will accommodate different tensions. I don't set my hook timing to make the check spring happy, I set it to compliment the hook timing and thread tension required to make the best stitch possible. I always encourage people to experiment with check spring setting to see the cause and effects. Regards, Eric I hope that is in order to start this thread again, because I did not find other general threads about this issue of check spring stroke adjustment. I agree with Dave4 regarding how books and most people will tell you to adjust the stroke. But I do find Erics comment interesting. I like to make two questions about it: 1) What can the problems be, that is caused by too little a check spring stroke? And I have seen these answers: - Needle can hit own thread - You can get thread tangled 2) What can the problems be, that is caused by too large a check spring stroke? And I have seen these answers: - If the check spring pulls the thread when loop below fabric is formed to be catched, you risk that you got too little a loop - A bit higher thread tension for the hook at parts of the way it pulls the thread down. I guess this means, that you want the check spring to be at resting position, when the needle start to rise from lowest position. I think the setting may be changed, so you have a larger stroke when you use thin fabric and short stitched (little use of upper thread each stitch). And when you use more upper thread each stitch, you man need shorter stroke. I tried to experiment with a Household Pfaff 30 machine, and it do not think to care about this stroke setting. It will work anyway: Edited July 24, 2021 by Gymnast Quote Sewing Machines in Detail, YouTube channel
Moderator Wizcrafts Posted July 24, 2021 Moderator Report Posted July 24, 2021 6 hours ago, Gymnast said: I hope that is in order to start this thread again, because I did not find other general threads about this issue of check spring stroke adjustment. I have learned to adjust the check spring tension and stroke according to the type of material and thread I am using. My most common combination is #92 (T90) bonded nylon thread, top and bottom, with a #19 (120) needle, into about 1/8 inch of leather, plus or minus. On my long arm machine, the top tension is fairly high most of the time. This is because I upgraded the tension spring to a heavy duty type. ;-) By running not too loose tensions I get tight stitches on the top and bottom of the work. (Aside: there are exceptions where I back off the top and bobbin tensions). I find that with this machine, which has been upgraded to use a Juki U hook and take-up lever, The top thread tends to snap as it passes around the hook. I can offset this by feeding a little more thread during the downstroke by playing with the check spring stopper and its position in the curved slot. It only takes a minute or two to find this setting and it makes it so much smoother to sew. Shortening the throw of the spring causes the top thread to be more slack on as the take-up lever starts down. The position of the screw in the slot in the disks fine tunes this. A standard factory setup usually has the screw in the dead center of the disks. Rotating the disks to the left increases the slack thread tension and vice versa. As for the travel, I always ensure that the spring holds the top thread taut until the needle fully goes through all layers. I NEVER let it continue holding the thread to BDC! That is asking for skipped stitches. The needle thread should have a little slack at BDC which increases as it moves up 3/32 inch to form a good loop for pickoff time. I have literally seen loops disappear on the upstroke when the check spring throw is too long. It is easy to watch this process on a shoe patcher. All of this is my opinion, based upon my own findings with my own sewing machines. Your results may vary. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Wyowally Posted August 3, 2021 Members Report Posted August 3, 2021 Not sure if this is related, if not, apologies! My Singer 111w155 has a check spring that bounces twice while the arm is on the upstroke. First bounce is just a blip, then the second is more pronounced, right when the arm is close to finishing going up, check spring is pulled about max, and the upper thread has cleared the case opener finger. I have cleaned and checked the bobbin case tab, the opening for the tab in the needle plate, and the thread opening in the feed dogs. It is like something is snagging or adding tension to the upper thread. From my description, is there a check spring adjustment that may be out of whack? Quote
Moderator Wizcrafts Posted August 3, 2021 Moderator Report Posted August 3, 2021 4 hours ago, Wyowally said: Not sure if this is related, if not, apologies! My Singer 111w155 has a check spring that bounces twice while the arm is on the upstroke. First bounce is just a blip, then the second is more pronounced, right when the arm is close to finishing going up, check spring is pulled about max, and the upper thread has cleared the case opener finger. I have cleaned and checked the bobbin case tab, the opening for the tab in the needle plate, and the thread opening in the feed dogs. It is like something is snagging or adding tension to the upper thread. From my description, is there a check spring adjustment that may be out of whack? Your needle/hook timing is probably retarded. The hook should arrive at least 1/16" above the eye after the needle lifts 3/32" above BDC. I time mine a little higher up in the scarf. Until I did the top thread made a snapping sound going around the hook and the check spring double or triple stroked. Advancing the timing can cure this. Once you time the machine properly your check spring adjustments will be more effective. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
