Members Jason046 Posted March 5, 2017 Author Members Report Posted March 5, 2017 Thanks. Yea it's really frustrating. The randomness of the splotches and area is what is weird. I tried prepping with alcohol before dieing also with the same result. Not sure what is going on but it comes right off as soon as I start to apply. How long do yall wait before applying? Is there a way to clean these off before dieing or once they are on is that pretty much it Quote
Members Tugadude Posted March 6, 2017 Members Report Posted March 6, 2017 I don't think you ever answered the question of which Fiebings dye you are using. Which is it? Quote
Members Mattsbagger Posted March 6, 2017 Members Report Posted March 6, 2017 If it's contact cement you can rub it off with your finger or an art gum eraser. Quote
Members Jason046 Posted March 6, 2017 Author Members Report Posted March 6, 2017 It's fiebings usmc black Quote
Members Mattsbagger Posted March 6, 2017 Members Report Posted March 6, 2017 1 hour ago, Jason046 said: It's fiebings usmc black I would not use usmc unless you really like buffing. It is the bane of rub off from what I have read. I use the Pro/oil (which has no oil). With good results. Do a search on here on the USMC and you will see what I mean. Quote
Members Jason046 Posted March 6, 2017 Author Members Report Posted March 6, 2017 Thanks for the advice. What is the difference between the pro dye and those dyes. I have noticed it is a pain with all the buffing. So use the pro with the resolene. I have noticed the red and brown seem so much easier Quote
alpha2 Posted March 6, 2017 Report Posted March 6, 2017 I have seen a lot of posts about USMC black, none of it good. Also, try spraying the Resolene on, then there is no rubbing. After it dried you can buff it but as it's dry, it won't take off the dye. Quote So much leather...so little time.
Members Mattsbagger Posted March 6, 2017 Members Report Posted March 6, 2017 3 hours ago, Jason046 said: Thanks for the advice. What is the difference between the pro dye and those dyes. I have noticed it is a pain with all the buffing. So use the pro with the resolene. I have noticed the red and brown seem so much easier USMC has WAY more pigment in it. More than ever needed. Quote
Members Jason046 Posted March 7, 2017 Author Members Report Posted March 7, 2017 I have tried to spray it but when I do it seems to be thick and have bubbles from the water. Will this go away after it dries Quote
Contributing Member fredk Posted March 7, 2017 Contributing Member Report Posted March 7, 2017 The bubbles will pop but leave minute circular marks looking like tiny holes. Quote Al speling misteaks aer all mi own werk..
