Members Puttstradamus Posted January 26, 2020 Members Report Posted January 26, 2020 On 7/11/2019 at 7:35 PM, RockyAussie said: I stumbled on this while having a look around on the Campbell Randall web site the other day. http://www.campbell-randall.com/public/index.php/product/fav-1498c-roller-foot-with-30mm-1498-roller If you go back and have a look into the parts section, in this case the FAV parts section there is a large amount of various feet for these skivers. I have a Fav and a Fortuna skiver and have been able to interchange the feet on them so I suspect that this should fit the Cobra as well. There is also an off centre pin that can rotate that holds the feet and that may be handy to have as well. I would give it a try as I think it would work and if so the amount of other variable parts such as the feed rollers and feet could be very handy knowledge to others including sellers on here. There is a member on LW that may be able to assist as well ..... @CampbellRandall Would this foot fit the Cowboy cb801? Quote
RockyAussie Posted January 26, 2020 Author Report Posted January 26, 2020 3 hours ago, Puttstradamus said: Would this foot fit the Cowboy cb801? I think so but you could check by asking for the more info section on Campbell Randall or pm a message to member @CampbellRandall Quote
Members Puttstradamus Posted January 26, 2020 Members Report Posted January 26, 2020 17 hours ago, RockyAussie said: I think so but you could check by asking for the more info section on Campbell Randall or pm a message to member @CampbellRandall Thank you! Quote
Members Logans Leather Posted September 3, 2020 Members Report Posted September 3, 2020 Many skiver manufacturers already make roller feet and have them readily available for purchase. Many manufacturers feet are interchangeable on many other manufacturers’ machines. Talk to Ron Kay at RSK Sales (formerly Melanie Machine Co) they specialize in slivers of all brands and ages and would most likely be able to help you 818-468-0579 i have always found them to be very knowledgeable and helpful. Quote
