3.5" above your cone is not nearly enough. From the base where your thread sits you should be at least 17" to the first guide loop. It doesn't matter how far it is to the winder. Even with smaller poly/cotton thread you need more distance. You could also add another guide between the first guide and the winder. If you do that, don't make a loop for the thread on the end of a wire. Your thread will throw a half-hitch around it and hang up. Use a longer piece of wire, install a guide at least 6" down from the top so it can't wrap around and get caught. Also, the older the thread, the kinkier it gets. I would start with getting your first thread guide quite a bit higher than it is now and go from there.
Regards, Eric
When I made a motorized bobbin winder I needed a thread guide for it but wanted it adjustable. Looking in one of my junk boxes I found the legs off a cheap camera tripod, fitted a wooden block with a couple of eyebolts on the top and attached it to the base of the winder. It worked so well that I made a free-standing one so that I could use the large spools with a portable machine.
Extends high enough to let the thread unwind easily.
Dikman, Neat, I am going to see if I can find one of my old tripods.
