It's a mystery to me how you can break those threads in normal use with just your hands. It seems you have to hit that thumb knob hard with a hammer to obliterate the threads on the shaft (they seem hard and brittle to me.) Perhaps tilting an unmounted head back to rest on the hand wheel is a common source of injury if the thumb knob hits the surface with any force.
The way they usually break is someone uses channel lock pliers to try and force the knob. The working part of the mechanism does tend to get stiff. As a matter of routine maintenance, I remove the spindle and shoot some oil in the shaft to keep things moving smoothly. One of the machines I'm rebuilding is getting a new hand wheel as well. I found original Singer shafts for $115.00.
Regards, Eric
Regards, Eric
Did you find the threaded and tapered point spindles? I need one for sure. Where did you get yours?
Posted IMHO, by Wiz
It's funny you should ask. That's about the only part of that mechanism that doesn't break easily. I have several used ones I've collected over the years. More than happy to send you one. Pm me your address and I'll get one on the way.  Universal Sewing and DSI Sundbrand both carry them as well.
Regards, Eric
  • 4 years later...
Is the belt between the top and bottom shafts intact ? No feed, if that belt's broken or stripped ....
The model number giveth, and the subclass taketh away ......... Sometimes
maybe safety clutch triggered - if it has one.
On 2/26/2022 at 10:54 AM, Dduggan said:
I’m looking at buying a 111w101 but I can’t get it to feed the leather I’m trying to sew any ideas? The needle goes up and down but it won’t feed at all.
Try adjusting the stitch length,turn the knob will pushing in clockwise makes it longer (as long as the threads on the shaft aren't broken)
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
