sewing fabric light to medium fabric (polyester, satin, suede) ect
here are some local options (i have a leather machine already) so this one is just for fabric stuff
any red flags for a particular model?
Pfaff 138-6/21
 Pfaff 438-6/01 900/51-BS,
 Pfaff 1445,
Pfaff 439,
 Singer 241-12
Singer 31-15 v
zigzag would be prefered so i guess a pfaff may be the winner ?!
thankyou for any input / advice!!
The Pfaff 138 gets my vote. There's a detailed topic on that machine:
Uwe (pronounced "OOH-vuh" )
Links: Videos
I have a pfaff 138-6 and it is a Tailor's sewing machine.  It should come with lots of feet.  I have been looking for a wheel presser foot for light weight leather, but there, I have had no luck.
I like the pfaff 138.  There are 3 needle positions and max zig-zag width is about 5 mm and  max  stitch length is about the same... Will that suit what you want to do?
Cheers
Alex
I´d take the 138 too.
I once owned one - very smooth running machine when properly set up (as most other sewing machines too). It is more or less the forerunner of the 438. I´m not sure if it has a build it oil pup or if it is wick oiled (from a reservoir) most built in oil pumps work at high sewing speed only. Also the 438 has a timing belt which sooner or later needs to be replaced (maybe tomorrow - maybe in 5 years) and replacing these belts often is a pain ITA or cost some good money. The 138 has a drive shaft instead (is it called drive shaft?) which needs no replacement. The only known problem of the 138 is probably that the zigzag adjuster could be gummed but thats something you can solve with heat and oil w/o bigger problem. When your zig zag adjuster is not gummed - even better.
The 138 is well documented as well you find everything from manual to parts list and service instructions online. Though I have not checked for the 438.
However - If I had to choose I´d take the 138.
Edited by Constabulary
Another vote for the Pfaff 138-6..very solid machine.
I actually have ( amongst others ) a Singer 20U ( wanted it for the freehand embroidery potential due it's variable zig-zag ability ) and the larger zig zag ( 8 to 9mm bight )..now looking for a triple step zig-zag ( hoping to find a Bernina 217..rare now ) to supplement it.
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
"The 138 is well documented as well you find everything from manual to parts list and service instructions online."
Constabulary, you posted the above quote. I just became the owner of a PFAFF 138-6/21 BS machine. I have found an operators manual but no other written manual such as the service manual. Could you point me to a link to get one?  Thanks, Clem.
On 5/14/2017 at 9:27 AM, Constabulary said:
and the adjustment manual:
Adjustment Manual-Pfaff-138.pdf
Thanks for the list of manuals. I now think that I should be able to get my PFAFF 138 running very well
Pfaff 138-6 gets my vote too! I had one, but sold it. Regret that I had to sell it, but that was due to space. It was in the house. :( Not everyone loved it there as much as I did. LOL! Good luck, tell us what you end up with, please.
