Moderator Wizcrafts Posted July 6, 2017 Moderator Report Posted July 6, 2017 Recently, some topics have come up exploring the available options for inline presser feet on walking foot machines. Some involve altering existing inside and/or outside feet to form an inline pair. But, for owners of a Juki 441 clone, there are commercially available inline feet made by Cowboy Sewing Machines. Since I own a set of these inline feet, I've decided to post some photos I took of them installed on my Cowboy CB4500. I should mention that these feet must be installed as a set and that you need to be aware that they are much shorter than a standard harness foot set. This is especially true for the back presser foot, which looks kind of like a pseudo-pod on an amoeba. But, I digress... Remove the existing inner and outer harness feet, avoiding the tip of the needle. If you want to play it safe, remove the needle first. Next, loosen the stop screw on the inside inline foot and slide it all the way uo to the milled collar on the vibrating foot bar (that's what Singer named the inside foot bar a looooong time ago). When it tops out, line it up with the needle (reinsert the needle) and lock it down tight on the bar. Now insert the rear foot onto the presser bar and set it as low as it will go without falling off, or contacting the back of the inside foot. Then lock it down tight. Because the feet are so short, in order to get the back foot to contact a single layer of 8-10 oz leather, you'll need to open the faceplate and lower the presser bar at least 1/4 to 5/16 of an inch. Don't worry about lowering it all the way to the feed dog. Just lower it enough so it firmly contacts the top of an 8-10 ounce test strip. There are two flat head screws on the steel block that the presser bar feeds through. There is a crankshaft in front of this block that will expose both screws if you rotate the handwheel to the correct position. Loosen the screws and pull down on the rear foot until is is about 1/8 inch above the feed dog, then turn it so it is as straight as possible and lock down the screws. Once the rear foot is in contact with the test strip of leather, you may need to loosen the large Allen bolt on the crankshaft coming out of the rear face of the machine and manually position the inside foot so it makes contact with the top of the leather just as or just after the tip of the needle makes contact. At that point you should lock down that big Allen bolt. This should give you fairly good alternating feed. Reinstall the faceplate and thread the machine. Run some test stitches to balance the tension, foot pressure and edge guide (if wanted) on the right side. I ran my test strip using 12 ounce bridle leather, #277 Cowboy thread and a #25 Schmetz S point needle. My edge guide was almost touching the right side of the inside foot. The photos will tell the rest. I made a video that I have to upload to YouTube later on. I will embed it in a follow-up reply once the video is available. If anybody with a Cowboy, Cobra, Techsew, or a Juki 441 or clone wants a set, contact Bob Kovar, at Toledo Industrial Sewing Machines: 866-362-7397. He told me on July 5, 2017 that he has some ordered and they should be in his shop by the second week in July. I don't know their cost at this time. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Wizcrafts Posted July 6, 2017 Author Moderator Report Posted July 6, 2017 In case it's not obvious, the inline feet are used to sew very close to the right edge and slide past any hardware or raised leather that might be on the left of the needle. The width of the inside foot is the limiting factor. It is just over 1/8 inch wide, so you can sew a narrow strap, collar, lead, watchband or studded belt, without having the hardware deflect the foot and stitch line. The presser foot is inline and follows the vibrating foot. These feet are useful if you need to resew soles of shoes and boots. All you need is about 1/8 inch of leather protruding from the uppers to sew along the edge. Finally, because the inside vibrating foot is so tall, you can't sew as much thickness as with the harness feet. The maximum thickness is determined by the bottom of the needle bar's needle clamp in relation to the top of the inside foot where the needle hole is. It must not hit the top of the inside foot! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members craftsman827 Posted July 9, 2017 Members Report Posted July 9, 2017 Thank you for all your help Wiz. What machine are you using the inline foot on ? I have to choose a machine, my first. So many to choose from. I'm racking my brain. I make dog collars & leads, belts, wallets, what is a good machine to sew two layers of up to 10 oz. leather ? Do I need a flat bed, or cylinder arm ? Quote
Members Greybeard Posted July 9, 2017 Members Report Posted July 9, 2017 Please keep us in the know, as you get more info. Quote Never Stop Learning..... https://www.facebook.com/Greybeardtc/ https://www.facebook.com/The-Art-of-Being-Me-Richard-Lane-617168155076456/
Moderator Wizcrafts Posted July 9, 2017 Author Moderator Report Posted July 9, 2017 2 hours ago, craftsman827 said: Thank you for all your help Wiz. What machine are you using the inline foot on ? I have to choose a machine, my first. So many to choose from. I'm racking my brain. I make dog collars & leads, belts, wallets, what is a good machine to sew two layers of up to 10 oz. leather ? Do I need a flat bed, or cylinder arm ? As I wrote in the Subject title: I'm using a Cowboy CB4500. But, any Cowboy, Cobra, Techsew 441 clone will take these feet, including the popular Cowboy CB3200. The feet are special order from Toledo Industrial Sewing Machines. He just ordered a bunch during the first week of July, 2017. The should be in this week, if not already. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member JLSleather Posted July 9, 2017 Contributing Member Report Posted July 9, 2017 I have got to stop reading these posts. Now there's another thing I want even though I don't really need it Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Moderator Wizcrafts Posted July 9, 2017 Author Moderator Report Posted July 9, 2017 2 minutes ago, JLSleather said: I have got to stop reading these posts. Now there's another thing I want even though I don't really need it Don't kid yourself! That's what I thought when I bought these feet. Now, my last 3 repair and new build jobs have required these inline feet for the best results. The last job was resewing an added on decorative flap on the upper area of the top cover on a biker's saddle bag. Any other presser feet would have been less efficient. I only installed the inliners to post this article. Now, they are refusing to not be needed! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Wizcrafts Posted July 9, 2017 Author Moderator Report Posted July 9, 2017 Note: It took me a good 20 minutes to switch over to the inline feet and get the presser and vibrating bar heights and thread tensions right. The more jobs I can do with them on, the happier I will be! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Wizcrafts Posted July 9, 2017 Author Moderator Report Posted July 9, 2017 As promised, here is a video I shot on my phone, showing the Cowboy inline foot set in action, on my Cowboy CB4500 sewing machine. I narrated the clip while my bearded business partner, Dan Ragan, did the sewing. Before we teamed up in 2012, he had never even touched a heavy leather stitcher. Now, after a couple lessons, he sews like a champ! Note that I am not a pro shooter. This was done ad-libbing on my Samsung S5, not on a real video camera (my Canon is broken ;-(). Hopefully, next time I shoot a video, I'll have a real camera and my 12" reflector lighting. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members dikman Posted July 9, 2017 Members Report Posted July 9, 2017 Nothing wrong with that video, Wiz, looks fine. Bit of a motley bunch you've assembled! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
