Members Joelandersson Posted September 17, 2017 Members Report Posted September 17, 2017 First of all, Im new to leather working. Been doing smaller things for a year or so. Recently i have interested myself into dying and finishes. Ive been trying out various spirit based dyes and right now my favorite is the Fiebings Professional Oil Dye. I get great results with this dye and it penetrates the leather well. However i recently acquired a natural colored leather side 1,5mm thickness. It seems to have a light finish applied to it. Ive tried to dye this leather but the color only penetrates a very little amount. By very little i mean that a nail scratch penetrates the color and the natural color is exposed. Ive tried removing the finish with both denatured alcohol and aceton, same result. Ive even tried sanded the leather with 240 grit still bad color penetrating. So obviously something is stopping the dye to soak in. Could the fibers on top be compressed in anyway? I want to learn why it is behaving this way regardless if it can be fixed or not. Ive tried dip dying still bad results. Color penetrates flesh side very well but stops when reaching "grain side layer" Appriciate any help! Quote
Members Mattsbagger Posted September 17, 2017 Members Report Posted September 17, 2017 Where did you get the leather from? Pictures might help. I got some veg tan pigskin from Tandy that wouldn't dye and I returned it. Quote
alpha2 Posted September 17, 2017 Report Posted September 17, 2017 It sounds like it isn't veg tanned leather. Other leathers with a surface treatment aren't designed to accept dye. Quote So much leather...so little time.
Members Matt S Posted September 17, 2017 Members Report Posted September 17, 2017 17 minutes ago, alpha2 said: It sounds like it isn't veg tanned leather. Other leathers with a surface treatment aren't designed to accept dye. There are plenty of veg tanned leathers with a top finish. There are chrome tanned leathers without Since the dye is penetrating the flesh but not the grain it does sound like there is some surface treatment involved, perhaps a sealant or maybe just a glazing. Joel, post us a picture if you can. Quote
Members Joelandersson Posted September 17, 2017 Author Members Report Posted September 17, 2017 (edited) I will, cant get the pictures to upload from phone, but will try with the computer asap! Thanks for your replys! It is veg tanned according to the supplier which is a trusted one. Edited September 17, 2017 by Joelandersson Typo Quote
Members Joelandersson Posted September 17, 2017 Author Members Report Posted September 17, 2017 so here is a picture wich is dyed. this one i acctually sanded down abit before i dyed it. so without sanding the dye penetrates even less. Quote
Members gigi Posted September 17, 2017 Members Report Posted September 17, 2017 Have you tried Fiebing's Deglazer? https://www.tandyleather.com/en/product/fiebing-s-deglazer-4-oz 5 hours ago, Joelandersson said: Color penetrates flesh side very well but stops when reaching "grain side layer" In the picture looks like it works only on the grain side. It's easier to buy blank leather (natural, not finished). Quote Houston, we have a problem
Members Joelandersson Posted September 17, 2017 Author Members Report Posted September 17, 2017 44 minutes ago, gigi said: Have you tried Fiebing's Deglazer? https://www.tandyleather.com/en/product/fiebing-s-deglazer-4-oz In the picture looks like it works only on the grain side. It's easier to buy blank leather (natural, not finished). Picture only show dye atemp on tge grain side. Will de fiebing deglazer work much different than denatured alcohol:aceton? Quote
Members battlemunky Posted September 17, 2017 Members Report Posted September 17, 2017 After seeing the pics I don't see too much of a problem. How far are you wanting the dye to go? As long as it goes deep enough to avoid surface abrasion and minor wear, it should be good. If it is for some high wear item, dye it multiple times. Also, dampening with water a little prior to dye may help penetration too. Quote
Members Joelandersson Posted September 17, 2017 Author Members Report Posted September 17, 2017 2 hours ago, battlemunky said: After seeing the pics I don't see too much of a problem. How far are you wanting the dye to go? As long as it goes deep enough to avoid surface abrasion and minor wear, it should be good. If it is for some high wear item, dye it multiple times. Also, dampening with water a little prior to dye may help penetration too. As said that was after sanding the surface. Without sanding it is very shallow. i just thought you would be able to get the dye deeper. Right now it quickly conecentrate the color so its hard gettinf anything else than dark colors. Ill try the dampening tomorrow and reply with the results! Quote
