Moderator Wizcrafts Posted November 15, 2017 Moderator Report Posted November 15, 2017 20 hours ago, alexitbe said: I am now considering the Ho-sing g60 and I like the simplicity of the sew-pro 550gl. However, i am not sure we can get it this side of the pond That motor was the SewPro 500GR (I have one). About 3 or 4 years ago, after changing the metal the body was made of to aluminum and cutting the top speed in half, causing all manner of problems and complaints from users and dealers, the employees at the factory that built nothing but that motor went out for lunch and never returned. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
alexitbe Posted November 15, 2017 Author Report Posted November 15, 2017 Hi Wizcraft, So there is no chance of getting a SewPro then... That is a shame.... I am making gloves and I really need a slow motor... Any suggestions? Cheers Alex Quote
alexitbe Posted November 15, 2017 Author Report Posted November 15, 2017 14 hours ago, Kohlrausch said: Hi Alex, talk to Frank Brunnet. http://www.frank-brunnet.com/ He is the Cowboy Bob of our side of the pond. I will probably get one of those http://www.ebay.de/itm/leiser-230-V-Motor-800-W-passend-für-Industrienähmaschine/322847634323?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649 in the next couple of days. Greets Ralf C. Hi Ralf, Thanks for the contact, I had never heard of him. Do you know the minimum speed of that motor? I will be interested to hear your opnion of the motor should you buy it. Cheers ALex Quote
alexitbe Posted November 16, 2017 Author Report Posted November 16, 2017 Well, I remembered that I had an old Pfaff motor like this below. Surprisingly I am able to feather the pedal so that I can sew slowly. Admittedly I cannot control exactly when it stops, but in such cases where I need precise control ie when sewing the finger tips, I can turn the wheel by hand for several stitches. I have only ever used servo industrial motors, but I might consider using induction motors from now on. This is not ideal,but then again I cannot find an ideal servo motor either... Quote
Members Constabulary Posted November 16, 2017 Members Report Posted November 16, 2017 These motors are not bad! Especially for lighter applications - but when you sew slow all the time they tend to become "quite warm" and you can smell it. however they are really nor bad! Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dikman Posted November 16, 2017 Members Report Posted November 16, 2017 I can't read the spec. plate, but that looks like a brush-type motor. The screw at the top looks like a brush-holder mount, in which case it's the same type as found in electric drills etc. (not induction). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Kohlrausch Posted November 25, 2017 Report Posted November 25, 2017 (edited) On 14.11.2017 at 8:57 AM, alexitbe said: Hi Ralf, Thanks for the reply. I got a response from the seller and it seems like the whole range JM700-900 has a lowest startup speed of 300 rpm. This is a surpise since sewtex are advertising the JM700 as starting at 100 rpm.. I am now considering the Ho-sing g60 and I like the simplicity of the sew-pro 550gl. However, i am not sure we can get it this side of the pond Hi, this appears to be the motor Sailrite is demonstrating here against their MC-SCR-system. They stopped the sewpro - set to slow sewing - with one finger. Greets Ralf C. Edited November 25, 2017 by Kohlrausch Quote
