Members Kromide Posted January 1, 2018 Members Report Posted January 1, 2018 im looking for a similar style belt slide to attach a strap to a holster. does anyone know what to search for or what the style is called? ive been looking all day with no luck. Quote
Members Dwight Posted January 1, 2018 Members Report Posted January 1, 2018 You are basically looking at proprietary equipment spec'd out and created for that particular holster maker. I doubt if you will find anything, . . . as I believe that is a Galco holster, . . . and I've personally never seen them on any other holsters. But, . . . best wishes on your search. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Stetson912 Posted January 1, 2018 Members Report Posted January 1, 2018 I will think Dwight is right. However you can make due with a single loop slider. That's essentially all it is. Quote
Members Kromide Posted January 1, 2018 Author Members Report Posted January 1, 2018 yeah i had figured it was proprietary to them as i could not find them i was just looking for something of a similar function not design ill look into single loop sliders again but i was not finding much with a hole for a screw or rivet. thanks for yalls help/ replies! Quote
Members Stetson912 Posted January 2, 2018 Members Report Posted January 2, 2018 I would make a short strap that wraps around one side of the single loop. That way you can stitch/rivet/screw it to the holster. Then the shoulder strap would go around the other side of the loop and fasten to the other part of the shoulder strap with a Chicago screw or something like that. Quote
Members Kromide Posted January 2, 2018 Author Members Report Posted January 2, 2018 yeah that was my thought as well, was just needing to actually find the part now ive got my patterns made up and a proof of concept made thanks for helping Quote
Members Stetson912 Posted January 2, 2018 Members Report Posted January 2, 2018 buckleguy.com has real nice hardware. You could check them out. They cast all their hardware out of solid brass and have a number of finishes as well. Quote
