Members micktx Posted January 15, 2018 Members Report Posted January 15, 2018 Hey Folks, Wondering if there is a mechanism to turn my 29-4 into a hand crank? Quote
Moderator Wizcrafts Posted January 15, 2018 Moderator Report Posted January 15, 2018 3 hours ago, micktx said: Hey Folks, Wondering if there is a mechanism to turn my 29-4 into a hand crank? Look for a bolt-on Brodie knob for the flywheel. The knob should be adjusted so it has enough clearance to turn freely, letting you hand spin the flywheel. Many 29 models already have this handle installed. Auto parts stores and Walmart usually sell them, as do many sewing machine dealers. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Yetibelle Posted January 15, 2018 Members Report Posted January 15, 2018 I think Wiz is referring to the Knob you can add to the hand wheel. There is a spot on the hand wheel you can drill and then add the knob so it makes it a crank. Also - you can get a few parts and move the hand wheel to the side of the machine. Those parts can be hard to come by if they didn't come with your machine. Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
Members Cascabel Posted January 15, 2018 Members Report Posted January 15, 2018 I just stick my finger between the spokes on the wheel on my 29-4, and spin it that way. Mine turns quite easily, because it's well oiled. Never saw the need for a hand crank on it. Mine has a treadle, but I never use it. Quote
Members Darren Brosowski Posted January 15, 2018 Members Report Posted January 15, 2018 (edited) I have brand new Chinese wheels with the timber handle Not sure what else you need but I may have the hub and shaft as well. Edited January 15, 2018 by Darren Brosowski ADD Picture Quote
CowboyBob Posted January 15, 2018 Report Posted January 15, 2018 They have a 29-4 so 29K the hub & shaft won't fit,since it only has 2-holes & the 29K hub has 3. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members micktx Posted January 16, 2018 Author Members Report Posted January 16, 2018 Wow! Thanx for all of the response. Really do appreciate it. I'll be looking for the pieces-parts to convert. Quote
Members Constabulary Posted January 16, 2018 Members Report Posted January 16, 2018 Do you just need just a knob for the hand wheel or a complete conversion to a front crank as Yetibele it has shown? The complete conversion kit (if it will fit at all) for sure will cost a lot of money - not sure if it is really worth converting a 100 years old machine that way. However - you only can convert to front crank if a gear is mounted on the top shaft in front of the drive cam. Open the rear cover and check. If there is no gear you have to pull the top shaft and install a gear. Pulling the top shaft means disassembling almost the complete machine. And thats really not worth it - in my opinion. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members micktx Posted January 16, 2018 Author Members Report Posted January 16, 2018 Thanx Constabulary. I'm finding out that the complete conversion is going to be a few ducats. Will probably go with the Knob. Quote
Members shoepatcher Posted January 20, 2018 Members Report Posted January 20, 2018 I believe the 29-4 does not have the front tooth cam gear that is bolted to the top shaft. It has the back half of the gear that the pitman arm fits in but not the forward section that the short shaft gear mates to drive the front mounted shaft that comes thru the hub. Some of the early 29K's had the front mounted shaft on certain models but not the 29-4. Changing means pulling the top shaft plus the bub will not mount to the casting because of a different face plate. glenn Quote
