Hi,
I need help in fixing the recently brought weaver draw gauge for my belt project. I tried on veg tanned leather and found the issues.
1) The blade screw is not flat to the leather, causing pushing upwards.
2) The handle is overturning and not giving good grip to hold.
3) The blade is not parallel to the handle. After cutting an inch, the leather stuck between blade and handle.
After sending mail to Weaver for support, they sent me the below mail to fix the screws. i did tried and seems like still issue with the blade angle to the handle and does't want waste the premium leather for that. Is there any way to accurately measure the angle and fix the problem? Thanks for the help.
Hello,
We got your e-mail about the draw gauge. There are set screws on the front of the draw gauge that will adjust the handle, so the handle does not overtighten. That should take of issues #2 and #3.
Thanks!!
Allen Burkholder
Machinery Sales
Weaver Leather
1-800-932-8371 Ext 223
You can file or sand off a little amount of threads on the end of the locking screw #1. That will allow it to tighten the blade with the head parallel to the ground, if you take off just the right amount. Hit and miss filing.
The sideways screw pitch adjustments should let you get a clean, straight cut.
If you find you cannot master this tool, consider returning it and getting an all wood strap cutter that uses a razor blade.
Posted IMHO, by Wiz
Thanks for the reply. Due to the blade angle issue , not able to use the tool. I am not able to rotate the screw accurately, After after cutting certain length the leather stuck between blade and handle, i have to remove the blade to take the leather out. And again i have to start with making the straight edge and guess work of screw rotation.
i purchased this tool during hanks giving sale and started using January first week. The return period 30 days passed and only email support they are providing. Wasted lot of time and leather on this. Anyone has experience with master leather tools? Are they any good for paying extra premium? I really disappointed with this draw gauge.
I will try with all wood strap cutter.
I tried a draw gauge a few years ago and did not have any luck with it. It was not from Weaver. I use the wooden strap cutters and they work good for me.
I do have other Master tools from Weaver. I love their Deluxe Round Knife and have cut out hundreds of holsters with it. Their hole punches and strap end punches are also very nice. I also like their EZ Edge Strap Edger, it has saved me tons of time.
Rohn
(John 8:32) And ye shall know the truth, and the truth shall make you free. (KJV)
Thanks Rohn.
After talking to them, they agreed to accept the return and is going back to them. I might got bad one but impressed with their customer care.
Yesterday i received Master tool strap end punch(1 1/2), build quality is good and worked nice. Just ordered all wooden strap cutter and waiting on that.
  • 2 weeks later...
I'll admit I rarely if ever use draw gauges anymore as I have a strap cutting machine but my experience, for whatever its worth, is I always had the best luck with the El Cheapo wood draw gauges that you can pick up for cheap. They are a super simple design and they must be nearly indestructible because the old tandy one I have in my shop is probably 30 years old.
I guess that there are "tricks" that I am not even aware of but I have successfully used a draw gauge for over 50 years. I think that pulling slightly into the leather is a big part of the trick after the adjustments mentioned by Weaver. For me, the wood/razor blade thingys are useless junk?
Maybe it is all in what you learn on and get used to.
Rohn
Very true,  I have an el cheapo from Tandy, and it works just fine! I can see having to replace the blade sometime down the road, but that will be cheap and simple to do.
I also use a cheap wooden strap cutter, always worked great, no problem as long as you keep the blade sharp.
