Members Markwell Posted February 8, 2018 Members Report Posted February 8, 2018 Howdy! I have made belts and straps in the past. But I have never been too systematic with the holes I punch into a belt. I just used what fit the buckle. Thinking about it though, especially when making templates, I'd like to use a standardized hole size. Is this even possible? Is there a hole size for belts that fits most buckles? Much obliged, Mark Quote
alpha2 Posted February 8, 2018 Report Posted February 8, 2018 I've found that most buckle pins are at least close to a standard size. If a particular buckle had one that was considerably tiny or large, you might change the hole size. For instance, with narrow ladies buckles, I use a Craftool #02 1/8" punch. For almost all my other belts I use a Craftool #07 7/32" oval punch. Round punch instead of oval I use the #04 5/32". Quote So much leather...so little time.
Members Retswerb Posted March 30, 2018 Members Report Posted March 30, 2018 I’ve seen several mentions here of oval belt holes. What’s the advantage? Quote
alpha2 Posted March 30, 2018 Report Posted March 30, 2018 (edited) Think of it like this. If you put a round pin, in a round hole, no problem. If you put a round pin in a round hole at an angle, you will wish you had an oval hole. (Actually, with enough wear, you will have an oval hole). In use, the pin in a buckle lays in the billet hole at an angle. Edited March 30, 2018 by alpha2 Quote So much leather...so little time.
Members Goldshot Ron Posted March 30, 2018 Members Report Posted March 30, 2018 Years ago I purchased a CS Osborn oval punch. It was the smallest they made. Because of the bevel of the punch, the hole is larger than ideal. Who makes oval punches that would make a nice hole? Ron Quote
alpha2 Posted March 30, 2018 Report Posted March 30, 2018 All of the round and oval punches I have will leave an overall hole larger then the hole at the end of the punch. I guess you'd have to start with a smaller than ideal punch, to arrive at the size you're looking for. Quote So much leather...so little time.
Members Retswerb Posted April 2, 2018 Members Report Posted April 2, 2018 That makes sense. Thanks for the info. Quote
