Members JMixx Posted March 3, 2018 Members Report Posted March 3, 2018 Hello all! This is the first thing I've made that is an actual project, and not just trying out stitches, or goofing around with stamps, using scraps. I would welcome suggestions; please bear in mind that this was made with a Tandy stitching awl, a scratch awl (for some of the thin lining leather), and no stitching clam, pony, or horse. I am "making do" until I can get a better awl and (probably) a pony. Can anyone tell me the functional differences between a clam, pony, and horse? (Other than the obvious differences in construction) Which is the most "user-friendly" for a beginner? What are the pros/cons of each? I'm guessing that any of them would be an improvement on my "two-rigid-cutting-boards-and-two-C-clamps" arrangement that I used for this cuff. Quote Making some progress... "Happiness hoarded is diminished."
bikermutt07 Posted March 3, 2018 Report Posted March 3, 2018 That is a pretty elaborate first project. Tackling binding on your first go is pretty ballsy. Of course you know your stitching will improve with time. All the rest of it looks evenly spaced and consistent. Great job. Capacity is really the only pro or con between the three horses. The clam and pony are obviously more portable than the horse. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
alpha2 Posted March 3, 2018 Report Posted March 3, 2018 Regarding capacity, you need to decide what the dimensions of your projects are likely to be. You don't want something that doesn't have the span or depth to get your work into. My clam has a bolt running through from side to side that limits the size of my projects. There are many designs that use different methods to create tension on the project. Google stitching clams, ponies, horses etc. for a lot pics of the different styles available. Great first project! Quote So much leather...so little time.
Members Mattsbagger Posted March 3, 2018 Members Report Posted March 3, 2018 On 3/3/2018 at 3:47 PM, alpha2 said: Regarding capacity, you need to decide what the dimensions of your projects are likely to be. You don't want something that doesn't have the span or depth to get your work into. My clam has a bolt running through from side to side that limits the size of my projects. There are many designs that use different methods to create tension on the project. Google stitching clams, ponies, horses etc. for a lot pics of the different styles available. Great first project! Expand You can always take the bolt out and use a bar clamp on bigger stuff. I have also clamped stuff to the outside of my pony. Purses and such. Used a ruler with binder clips to make stuff not flop over when stitching. Necessity is the mother of invention and all that. Lol Quote
bikermutt07 Posted March 3, 2018 Report Posted March 3, 2018 For the big stuff, I lay it flat on the table and hang the edge off the front. Then lay a smaller quartz slab on it to keep it still. Stitching sideways is pretty fun. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
alpha2 Posted March 3, 2018 Report Posted March 3, 2018 On 3/3/2018 at 5:20 PM, Mattsbagger said: You can always take the bolt out and use a bar clamp on bigger stuff. I have also clamped stuff to the outside of my pony. Purses and such. Used a ruler with binder clips to make stuff not flop over when stitching. Necessity is the mother of invention and all that. Lol Expand I have done the ruler and binder clips, too! That floppy work is annoying, for sure. I've also done the "hang it over the edge" bit. Whatever it takes. Quote So much leather...so little time.
Rockoboy Posted March 4, 2018 Report Posted March 4, 2018 I believe a stitching horse is a bigger unit, possibly with a built-in seat, whereas a pony is a smaller clamping/holding device. The pony is more suitable for a tabletop or held between your legs. A clam is a simple clamping deveice that might or might not have any sort of fixing to hold it (like the horse or pony). Of course, there is a huge possibility I am totally wrong in everything. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
alpha2 Posted March 5, 2018 Report Posted March 5, 2018 I'm inclined to agree with Rockoboy, but I have to insist on the same disclaimer. Because, well, experience. Quote So much leather...so little time.
Members Mattsbagger Posted March 5, 2018 Members Report Posted March 5, 2018 Basically the are the 3 styles of holding devises. Variation are innumerable. Clam on top, pony on left, horse on right. These also are terms that sometimes are interchangeable like pricking iron and chisel. In my experience anyways. Quote
alpha2 Posted March 5, 2018 Report Posted March 5, 2018 Matt is correct. AGAIN! Seriously, Matt? Quote So much leather...so little time.
