One of our customers wanted a Greek Medusa holster.  This artwork is from an historical relic carving and the lettering is an ancient alphabet.
Learnleather.com
That’s pretty cool Mike!  The leather is so grainy - what type leather are you using?
Gary
Cowboy 4500, Consew 206RB-4
Mike, did I understand correctly that you use in this work a beveler without carving?
And I join Gary in the question of leather.
Looks very good!
Andrey.
Edited by ABHandmade
Gary
It look grainy because its small.   Hermann Oak A grade
Looks very good!
Andrey.
I am cutting it as well.
Learnleather.com
What do the 'RUNES' say ?
Sam:)
Very beautiful cuts and beveling I admire and understand how much I still have to study and train.
Sam:)
Korevantes but phonetically
Thank you.
Learnleather.com
Looks very good!
Andrey.
@immiketoo I think @ABHandmade wanted to know if you recommend bevelling without carving on any project?
I do it all the time on fine details.  I didn't read his question like that though.  The runes are not cut, only beveled.
Learnleather.com
This is all my bad English :)
I was really interested in whether the beveling was used without a cut. Because I did not see the traces of a cut on the runes.
Mike confirmed that this is the case.
Thank you!
Thank you!
Do you see traces of a cut anywhere else?
Learnleather.com
Clearly expressed - no. But on the runes there is clearly a very smooth difference in heights, which is usually achievable only in the case when the leather is not cut. I wanted to check if my guess is correct.
Ok good.  I thought I was slipping!
Learnleather.com
It is exactly that I do not see any obvious traces of the leather cut and caused my admiration for your professionalism.
