Members bluesman1951 Posted May 20, 2018 Members Report Posted May 20, 2018 I left my Toro 3000 on too long just forgot about it .Went to use it and it won't work . I have the red light at the switch and nothing else.Have I killed the motor by leaving it on too long ? Quote
Moderator Wizcrafts Posted May 20, 2018 Moderator Report Posted May 20, 2018 What make and type of motor is on your Toro? If it's a servo, leaving it on shouldn't make any difference as no serious current flows until it is spinning. If it is a clutch motor, it generates heat all the time it is on and could overheat if not properly cooled. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Ken Nelson Posted May 20, 2018 Members Report Posted May 20, 2018 Have you checked the fuse on the motor? Quote
Northmount Posted May 20, 2018 Report Posted May 20, 2018 Unplug it, leave it sit for a while, then try again. May have to re-do the setup. This happened to someone else on the forum, but don't remember who or when. Another party had damage due to lightning strike nearby when it was left turned on. Some electronics seem to be very sensitive to power line transients. Good luck/ Tom Quote
Members dikman Posted May 20, 2018 Members Report Posted May 20, 2018 (edited) What do you mean by "too long"? Electronics are generally pretty reliable these days so leaving it on shouldn't normally be an issue. I left one of my servos on for over a day with no problems. Look for a fuse, most likely on the back of the control box, and check that, if that's ok try what Tom said and unplug it for a while. If it still doesn't work then it's most likely been damaged by a power surge or spike on the line. Sometimes, if you know what you're doing and you're very lucky, you can open up the control box and may see a damaged component that can be replaced - but these days you've got to be real lucky for that to work! From what I've found you can't buy the control box separately, only consolation is complete servos are relatively cheap. Edited May 20, 2018 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
