Members Treesner Posted August 2, 2018 Members Report Posted August 2, 2018 does anyone make a double cap rivet thats easy to set however with a flat front and solid non hollow top like the tops of copper rivets. I basically want the appearance of the copper rivet but don't need the extreme hold and slow install time. Quote
Rockoboy Posted August 12, 2018 Report Posted August 12, 2018 I don't think this is possible. The stem has to be tubular, as that is how the rivet is set. If you place your work on a hard, smooth and flat surface, when you set the double cap rivet, the end result will be a flat cap on the bottom side. Turn your work over and gently tap the other side of the double cap rivet on the hard surface and then you have a flat head double cap rivet. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members Treesner Posted August 14, 2018 Author Members Report Posted August 14, 2018 On 8/11/2018 at 6:05 PM, Rockoboy said: I don't think this is possible. The stem has to be tubular, as that is how the rivet is set. If you place your work on a hard, smooth and flat surface, when you set the double cap rivet, the end result will be a flat cap on the bottom side. Turn your work over and gently tap the other side of the double cap rivet on the hard surface and then you have a flat head double cap rivet. hmm do you think I could flatten it first before setting? the reason I'm looking for this is so that I can cut the edges off and turn the circle into a square Quote
Members brmax Posted August 15, 2018 Members Report Posted August 15, 2018 How about using some chicago screws, in the same way. Squared good day there Floyd Quote
Rockoboy Posted August 15, 2018 Report Posted August 15, 2018 15 hours ago, Treesner said: 15 hours ago, Treesner said: the reason I'm looking for this is so that I can cut the edges off and turn the circle into a square I don't believe this is possible with a double cap rivet. The cap of the rivet and the stem of the rivet on the male side are 2 separate pieces. I had to destroy some rivets to disassemble an item recently, and this is what I found. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Contributing Member fredk Posted August 15, 2018 Contributing Member Report Posted August 15, 2018 44 minutes ago, Rockoboy said: I don't believe this is possible with a double cap rivet. The cap of the rivet and the stem of the rivet on the male side are 2 separate pieces. I had to destroy some rivets to disassemble an item recently, and this is what I found. double; I know you can't cut the edges and retain the integrity of the rivet head. Cutting off one part of the edge is one way I use to remove them. The Chicago screws is the way I think. You can buy square ones from Chinese sellers on ebay Quote Al speling misteaks aer all mi own werk..
Contributing Member fredk Posted August 15, 2018 Contributing Member Report Posted August 15, 2018 Found square head Chicago screws https://www.ebay.co.uk/itm/Solid-Brass-Square-Head-Binding-Stud-Leather-Belt-Bag-Chicago-Screw-Nail-Rivet/152694517062?hash=item238d4d6d46:m:mjGLK7T9Mvki-qyv6zAuvxw Quote Al speling misteaks aer all mi own werk..
Members KooperLee Posted August 23, 2018 Members Report Posted August 23, 2018 (edited) On 8/3/2018 at 7:22 AM, Treesner said: does anyone make a double cap rivet thats easy to set however with a flat front and solid non hollow top like the tops of copper rivets. I basically want the appearance of the copper rivet but don't need the extreme hold and slow install time. 4 Hi Treesner, recently I launched my new designs - double-sided rivets on my site http://dot-gas.com/jeans_rivet_p1.html I do flat cap and convex cap for the moment, both available for size 8MM and 9.5MM, and they can go with tacks in 3 available lengths 6.5, 8 and 12MM. They are made from the high-grade brass material and designed for high-end products, a perfect combination of appearance and functionality. Edited August 23, 2018 by KooperLee Quote ELEMENTRIMMING / DOT-GAS
Members Treesner Posted September 28, 2018 Author Members Report Posted September 28, 2018 On 8/22/2018 at 8:59 PM, KooperLee said: Hi Treesner, recently I launched my new designs - double-sided rivets on my site http://dot-gas.com/jeans_rivet_p1.html I do flat cap and convex cap for the moment, both available for size 8MM and 9.5MM, and they can go with tacks in 3 available lengths 6.5, 8 and 12MM. They are made from the high-grade brass material and designed for high-end products, a perfect combination of appearance and functionality. thanks are flat ones hollow/ two pieces? basically I want to grind away material so that I can make a square instead of a circle but all the ones ive done ive found they are two pieces and fall apart when I grind them unlike the pure copper ones Quote
Members bgl500 Posted October 2, 2018 Members Report Posted October 2, 2018 On 8/22/2018 at 10:59 PM, KooperLee said: These look fantastic and have been looking for rivets like this. Will certainly place an order. Hi Treesner, recently I launched my new designs - double-sided rivets on my site http://dot-gas.com/jeans_rivet_p1.html I do flat cap and convex cap for the moment, both available for size 8MM and 9.5MM, and they can go with tacks in 3 available lengths 6.5, 8 and 12MM. They are made from the high-grade brass material and designed for high-end products, a perfect combination of appearance and functionality. Quote
