Members jbuckingham Posted August 4, 2018 Members Report Posted August 4, 2018 Hello. I'm pretty new to the leatherworking thing and learning through trial & error & digging around online. So this might be a simple one... If I want to end thick leather cord (5-6mm let's say) like the examples below, how do I do it? Can't find any kind of tutorials. Also if I use braided cord how would I attach that to a clasp? (Oh one more thing - what's the metal hardware on the dark examples called? The one that's like an open loop...) Appreciate any advice/links. Thanks all! Quote
Members Matt S Posted August 4, 2018 Members Report Posted August 4, 2018 You can achieve results similar to the examples shown by whipping the two cords with some heavy thread. I'd probably stitch them together first for extra strength. For extra detail on longer runs try coxcombing. Alternatively you could crimp on a ferrule, apply heat shrink tubing or stitch on a tight leather collar but I think a long whip will achieve the result you want best. Quote
Members chrisash Posted August 4, 2018 Members Report Posted August 4, 2018 The whipping is rather simple Start with the short end about three inches before you need to start the whipping, lay it down the length of the whipping area and a little bit more then run it back up to the top again , so now you have one end plus the rest of the whipping cord at one end and a eye at the far end Now as tight as you can run the thread around and down the area until its just short of the eye, cut the tread and place through the eye Pull on the long tail at the start and pill the eye well into the whipping and cut off both ends left showing. a drop of varnish or clear glue will keep it all tight and in place You could hide a rivet etc under the whipping if you needed extra strength Quote Mi omputer is ot ood at speeling , it's not me
Members Tugadude Posted August 4, 2018 Members Report Posted August 4, 2018 (edited) This is a pictorial on how to terminate handlebar tape that details a method similar to what is described above. http://www.cyclofiend.com/Images/rbw/pdf/original_twineforsite.pdf The hooks are called fish hooks or open hooks, sometimes other names. Google brass fish hook wallet clip. You'll find lots of sources. Edited August 4, 2018 by Tugadude Trouble with link Quote
Members jbuckingham Posted August 4, 2018 Author Members Report Posted August 4, 2018 Ahh I see. Thanks everyone, whipping is a term I'd never heard of but it looks like something I can try. Cheers. Quote
