Members mick86 Posted August 10, 2018 Members Report Posted August 10, 2018 Gday. I've made a few bags. On one of them you see a textured finish but that wasn't what I wanted to do. I traced on a celtic design that I was going to punch in however I couldn't get the background tool into the tight corners and it just looked terrible so I used a different background stamp and crushed it all down. Is there a way I can get into the tight corners/spaces? A different tool or technique? Also after putting the texture on, it was all out of wack, no longer symmetrical. Was I too rough? was it too much water? Cheers Quote
Contributing Member fredk Posted August 10, 2018 Contributing Member Report Posted August 10, 2018 For background you do need a range of tools, from very small to the largest which your design can take. One of the common backgrounders is the simple cross-hatch as on Tandy A104 https://www.tandyleather.eu/en/product/a104-craftool-background-stamp Although this is very small, it might not be small enough. You can buy these tool very cheaply. Use a dremel type tool, or just a file to shape a backgounder to size and shape that you need For interlacing; the most important aspect imho is to have the widths of the ribbon the same size throughout. Modern drawings of interlacing are all nice and regular, but the ancients didn't have it that way; so for a 'rustic' / 'ancient' look the design can be a bit uneven As with all design stamping, but Celtic interlacing patterns especially, work slowly and carefully, taking breaks from it every-so-often Quote Al speling misteaks aer all mi own werk..
Members bullmoosepaddles Posted August 10, 2018 Members Report Posted August 10, 2018 Some of the background stamps are tiny, for projects like yours. Try finding a few of the smaller ones. I know it gets expensive fast. But its hard to drive a nail with a sledgehammer. If it matters. Love both of your pieces. The texture looks good for a mistake. We were asked to make some rune inspired work this past weekend. I started to study a book we bought a while back yesterday. May I ask if the rune pieces are wood or leather? And the size of the pieces? Thank you for sharing. Quote
Members Sheilajeanne Posted August 10, 2018 Members Report Posted August 10, 2018 7 hours ago, mick86 said: Also after putting the texture on, it was all out of wack, no longer symmetrical. Was I too rough? was it too much water? Cheers Wet leather stretches, and it's very common for this to happen when it's being tooled, especially if the piece is on the thin side. The only way to get around it is to fasten it to a non-stretchy backing piece with either rubber cement (which can be peeled off after) or tape. Quote
Contributing Member fredk Posted August 10, 2018 Contributing Member Report Posted August 10, 2018 (edited) 32 minutes ago, Sheilajeanne said: Wet leather stretches, and it's very common for this to happen when it's being tooled, especially if the piece is on the thin side. The only way to get around it is to fasten it to a non-stretchy backing piece with either rubber cement (which can be peeled off after) or tape. Also; cut the piece bigger than you need. Allow for the stretch, and then you can cut your required shape out, around your worked area when its completed btw; for doing fine interlacing patterns I ground the blade of a stubby flat screwdriver. I ground out the middle of the blade to leave two points. I actually made two, slightly different. Then I use this to draw over the wet leather, leaving two tracks. It means my ribbon width is always constant. I've not used them for several (many) years Edited August 10, 2018 by fredk Quote Al speling misteaks aer all mi own werk..
Members mick86 Posted August 11, 2018 Author Members Report Posted August 11, 2018 21 hours ago, bullmoosepaddles said: We were asked to make some rune inspired work this past weekend. I started to study a book we bought a while back yesterday. May I ask if the rune pieces are wood or leather? And the size of the pieces? Thank you for sharing. Thank you for your feedback bullmoosepaddles. I just started learning the runes this year myself. Very interesting stuff. I made the runes from birch wood. They are 9mm to10mm in the round blue bag and 13mm to 14mm in the textured brown bag and both are 3mm thick. I have made bigger ones but wanted some smaller pack ones. Quote
Members mick86 Posted August 11, 2018 Author Members Report Posted August 11, 2018 20 hours ago, fredk said: btw; for doing fine interlacing patterns I ground the blade of a stubby flat screwdriver. I ground out the middle of the blade to leave two points. I actually made two, slightly different. Then I use this to draw over the wet leather, leaving two tracks. It means my ribbon width is always constant. I've not used them for several (many) years That is a very good idea thank you fredk. Quote
Members battlemunky Posted August 11, 2018 Members Report Posted August 11, 2018 I have nothing to add to help with your questions but those are adorable little pouches. I could see those selling well when you are happy with them. Quote
Members kiwican Posted August 11, 2018 Members Report Posted August 11, 2018 Very cool for sure Quote
Contributing Member fredk Posted August 11, 2018 Contributing Member Report Posted August 11, 2018 4 hours ago, mick86 said: That is a very good idea thank you fredk. I dug through my tools and found the screwdriver interlacing markers. One makes a square edged lace the other makes a slightly wider round top lace; Just a rough drag thru some leather. I don't know if you can make it out the round top shape is to the top of the picture. Proper back-grounding would tidy the lines as well. And finally; if you're not totally set on using wood for your rune beads ~~ I use 'granite' polymer clay. Polymer clay is also known as FIMO and Sculpey. I use the Tandy Rune letters to impress the letter then I fill the grove with liquid polymer clay mixed with gold paint and gold glitter. The two top beads are FIMO straight from the packet, for the two lower I added white polymer clay to lighten them a bit. I make these for games as well as for necklace beads. They have been mistaken for real granite pebbles. A block of polymer clay is 2 ounces (58g) and I get between 14 and 18 beads from a block Quote Al speling misteaks aer all mi own werk..
