Members aden Posted August 11, 2018 Members Report Posted August 11, 2018 (edited) Hello everyone! I have read through a lot of the fantastic informational posts here on the forum and now understand the differences and uses for different sewing machines. So first, thanks for that. I am looking to purchase a sewing machine as a gift. I have found the Seiko STW-8B for £400 and was wondering whether that was a good price? It is in perfect working condition with no rust or fading. The current problem is that I’m not clued up on decent current prices for these things and I hope someone out there can shed some light on the situation Thanks! Edited August 11, 2018 by aden Quote
Members brmax Posted August 11, 2018 Members Report Posted August 11, 2018 Thats a nice gift! im thinking thats roughly 500$ US and thats a respectable asking price. As always its more important in the question with the local need and or popularity with a given product. So the brand to me is premium, with that clear. First is what benefits does the unit have, that is newer or are key to my actual use. With that, I could mean and do a newer type motor ( servo ). If particularly the work will be intricate leather work then a reducing speed; pulley system is a requirement. These if split can be 200$ US each. A thirty year veteran, sewing fabricator, will change out the old clutch motors to servo eventually and only say one thing, why didnt I do this earlier. Either of these items mentioned need a discussion in their own right For a seriously better discussion, some photos would benefit your questions to and from others, that are all helpful and glad to talk machines. Good day Floyd Quote
Members aden Posted August 11, 2018 Author Members Report Posted August 11, 2018 (edited) Thank you very much for your response! After my reading I am aware that a servo or speed reducer will probably be needed. But the person I am buying it for has wanted one for ages and I am sure they will be very happy to have something they can build on with their own modifications I will attach some photos of the unit as you suggested. Based on my research I believe this is a walking foot compound feed and very similar to the Singer 211, Consew 226 and Juki 563? It will predominantly used for upholstery but will probably get used for a number of other things as well. Edited August 11, 2018 by aden Quote
Moderator Wizcrafts Posted August 11, 2018 Moderator Report Posted August 11, 2018 From your photos it is obvious that this machine is set-up for upholstery sewing at higher speeds. It has a 2850 rpm motor and about a 3:4 pulley ratio. It will definitely get long seams sewn in almost no time! As for sewing slowly, that depends on the new owner being able to feather the clutch, or replace the motor with a servo motor. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members aden Posted August 11, 2018 Author Members Report Posted August 11, 2018 4 hours ago, Wizcrafts said: From your photos it is obvious that this machine is set-up for upholstery sewing at higher speeds. It has a 2850 rpm motor and about a 3:4 pulley ratio. It will definitely get long seams sewn in almost no time! As for sewing slowly, that depends on the new owner being able to feather the clutch, or replace the motor with a servo motor. Thanks for the great informative reply, Wiz! That is exactly what I was hoping to hear In your opinion, is £400 (~$510) a decent price for this or should I be looking at a cheaper price? Quote
Uwe Posted August 11, 2018 Report Posted August 11, 2018 Looks like the machine is in very nice condition, actually. Price seems reasonable, but obviously it varies across the globe. I've paid less for machines, but then I spent better part of a week making them work. This must be the Seiko model that was sold under the Consew brand as a 226 model here in the US. Parts are cheap and everywhere. These are great starter machines and they're reliable workhorses at the same time. The motor may be on the fast side, but the motor pulley itself looks just about as small as they come. If the clutch works well, it may not be a bad starting point for upholstery. The best way to find out is to just try it out. Swapping out the motor with a modern servo motor is relatively simple and you can spend as little or as much on a servo motor as you like. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
DonInReno Posted August 11, 2018 Report Posted August 11, 2018 Something that can catch people by surprise is how common it is for commercial machines to be repainted - if that’s the original paint it’s probably in very good condition. Most repaint jobs are very obvious while others need a closer look. At least some small chips in the original paint are sure to show through a new topcoat even if it’s been carefully sanded. Even if it’s been repainted the machine may be in fantastic shape. Also look closely along the thread path - if that’s the original paint I’d expect little wear on the thread take up and thread guides. Any first walking foot machine is a great gift worn or not! Quote
Members dikman Posted August 11, 2018 Members Report Posted August 11, 2018 If it hasn't been repainted then it's in remarkably good condition. Probably the best thing is to get the owner to do a couple of longish runs on it and listen for any odd noises and make sure the stitches are nice and even. Price-wise it's Au$870, which is pretty good here (I paid a LOT less for mine, but I was lucky!). One possible way to look for wear is to remove the two thread tension discs and look for wear lines where the thread has worn a path in the metal. Of course, if they've been replaced then this won't apply, but it's pretty unusual to have to replace these unless it's had very heavy usage. I'm very happy with my Seiko, they're great machines and as mentioned feet, bobbins etc shouldn't be hard to find. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members aden Posted August 12, 2018 Author Members Report Posted August 12, 2018 This is all incredibly useful information. Thanks a lot to all who have responded so far! Quote
