Members blafleur Posted August 17, 2018 Members Report Posted August 17, 2018 Still learning and finding best uses for different rivets. Looking on Buckleguy and Ohio Travel Bag's sites, there are caps listed with tubular rivets. Near as I can tell it works like the cap on a double cap rivet. Anyone have any experience with these? Are they are secure as a regularly peened tubular rivet? Quote
Rockoboy Posted August 17, 2018 Report Posted August 17, 2018 Do you have any pics? Otherwise, people might not end up commenting on the same thing you are talking about. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members blafleur Posted August 17, 2018 Author Members Report Posted August 17, 2018 Here is the rivet cap in question. https://www.buckleguy.com/rt8204-cap-for-rt8203-bocr2-100-per-bag/ Quote
Rockoboy Posted August 17, 2018 Report Posted August 17, 2018 I have never seen these before. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members Big Sioux Saddlery Posted August 17, 2018 Members Report Posted August 17, 2018 I use them only occasionally, usually only on something where both sides of the rivet will show, and it's unacceptable for the "splash" to be showing. I find them fiddly to set, even having a cap anvil on my riveters. Length is even more critical than if just splashing the rivets. I try to avoid having to use the caps if at all possible; I have found them more likely to fail, and if the cap pops off, there isn't much left holding because there isn't much room in the cap for the rivet to spread (which is usually the reason they fail) Quote
Members blafleur Posted August 19, 2018 Author Members Report Posted August 19, 2018 All the things I was concerned about. Thanks Big Soux. Quote
Members Big Sioux Saddlery Posted August 19, 2018 Members Report Posted August 19, 2018 You're welcome. In addition to the above mentioned reasons for not liking them, the last I checked the caps were available only in plated steel. I avoid using anything that can rust in my products, since I deal primarily with equine equipment and most equine equipment gets used and stored in a non-climate controlled environment. In other words, if it CAN rust, it WILL rust, and rust rots leather relatively quickly. Plated steel doesn't resist the moisture of the atmosphere and horse sweat very long before the plating peels off and the base metal rusts. Quote
alpha2 Posted August 19, 2018 Report Posted August 19, 2018 Big Sioux for the win! Jeff Quote So much leather...so little time.
Members Big Sioux Saddlery Posted August 20, 2018 Members Report Posted August 20, 2018 4 minutes ago, alpha2 said: Big Sioux for the win! Jeff Lol, wasn't trying to win anything, just educate Quote
alpha2 Posted August 20, 2018 Report Posted August 20, 2018 So, two birds...one stone! Quote So much leather...so little time.
