Hi all--I'm looking to do a cross stitching pattern on leather, and am looking for a tool that would allow me to make many small holes in a piece of leather. Ideally, a punch that puts a square of four holes at a time--I'm not sure such a thing exists, but if it does, I figured someone here would know.
Thanks in advance
Go to Springfield Leather or Weavers -ads at the top of the page.  They have stitching chisels that will do what you want to do!
Gary
I actually grabbed an overstitch wheel along with a jeweler's leather punch, but I'd like the holes closer. What is the smallest spacing available on an overstitch wheel?
Well it isn't cheap, but fine leather working offers a overstitch wheel set that comes with 7 9 10 and 12 tpi wheels. The 12 tpi wheel would be just over 2 mm apart.. that's the finest I have seen. http://www.fineleatherworking.com/leather-tools/pricking-wheel-set
Fine leather working had listed individual wheels. But says it's not available right now. You could contact them and ask when or how you can get them as well.
Welcome, easy to go bankrupt on that site by the way, I advise caution hehehe
Modern pricking wheels by Vergez Blanchard go as fine as 12SPI and their pricking irons to 14 SPI. A 2-tooth 14SPI iron is about €33 direct from them.
It wouldn't be difficult, with very basic tools, to cut a piece of square steel bar to suit the job, especially if you're just pricking rather than punching through the leather.
  • 3 weeks later...
You can buy perforating bar stock
You can buy 1/16" hole punches shaped like a pencil, or just the tubes for a rotary punch.  These are threaded.  Mount them in a piece or wood or grind/epoxy the four punches together and voila, a square, repeatable pattern.
Expect the leather to tear through all over the place if you get to 3mm and lower unless you back the leather with a tear-resistant textile.  All those holes makes it like the edge of a postage stamp.
Is this intended to be a single piece, ie the cross stitch on leather or cross stitch pattern that is accenting a larger item like a bag or purse?  The reason I ask is it seems like many perforated holes in leather will greatly weaken it when stressed, if it's a pattern that will be framed then will there be leather in the voids as accent?  Just trying to get a mental picture of the project...
