Members dikman Posted September 22, 2018 Members Report Posted September 22, 2018 Does anyone know the overall length of this needle? I haven't been able to find it by googling so far. This is the standard needle for my 111W117, which I've adjusted to take a 135x17 (but it's a shorter needle). This probably explains why i can't get the 1/2" under-the-foot that the brochure mentions as the needle bar is hitting the inner foot with this needle at 3/8" clearance. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted September 22, 2018 Members Report Posted September 22, 2018 (edited) Needle system 190 should solve the issue, its 4mm longer. 126 seems to be an uncommon needle. However my needle bar is not hitting the inner foot with 135 needle. Is for what ever reason your hook tip too low - probably because of the 111w117 had trimming device? Meaning if the hook tip is deeper the needle / needle bar has to go deeper too - don´t know just my 1st guess. Can you compare with your other 111? 190R http://www.dotec.com.tw/product_detail.php?p_id=61 135x17 http://www.dotec.com.tw/product_detail.php?p_id=33 Edited September 22, 2018 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dikman Posted September 22, 2018 Author Members Report Posted September 22, 2018 Thanks for that needle info, I'll have to see what I can find. According to the meagre info that I've found/been told about the 117, other than a few parts to do with the spring tensioning of the presser foot and the cutters it's basically the same as the 116, which in turn is basically a 153. I'll have a look but I reckon the hook assembly is likely to be a "normal" 111 type. In the other post I mentioned there was a knocking noise coming from underneath which turned out to be the hook hitting the needle. I lowered the needle bar to set the correct adjustment but this meant the needle bar was just touching the inner foot at the needle's lowest point. Unfortunately I have no idea what was used in this machine before but it appears that it must have been a longer needle than the 135 I've fitted. All good fun. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members koreric75 Posted September 22, 2018 Members Report Posted September 22, 2018 http://ismacs.net/needle_and_shank/needle-cross-reference-chart-flat-shank.html Quote Machines currently in use: Cowboy 3200, Adler 67-372, Singer 66, Singer 15-91
Members 111W Posted September 22, 2018 Members Report Posted September 22, 2018 Overall length of the 126x11 varies with needle size as the length of the eye and length of the point increase as the needle size goes up. I do not have the range of variance. The dimension from the furthest end of the shank to where you first come to the eye is 1.850" (47mm). Measured in the same manner, dimensions are 44.5mm (1.751") for system 190R and 1.530" (38.9mm) for system 135x17. Quote
Members dikman Posted September 22, 2018 Author Members Report Posted September 22, 2018 koreric, that chart is for flat shank needles, not round. 111W, that figure from the shank end to the eye explains it all. I've lost 8 mm in clearance by using a 135 needle. Thank you. Next time I'm near the (industrial) sewing machine supplier I'll ask them what's available to see if I can squeeze a bit more clearance from the beastie. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members koreric75 Posted September 23, 2018 Members Report Posted September 23, 2018 1 hour ago, dikman said: koreric, that chart is for flat shank needles, not round. my bad, was trying to hurry when i copied the link earlier and didn't see that... here you go http://ismacs.net/needle_and_shank/needle-cross-reference-chart-round-shank.html Quote Machines currently in use: Cowboy 3200, Adler 67-372, Singer 66, Singer 15-91
Members dikman Posted September 23, 2018 Author Members Report Posted September 23, 2018 Thanks mate, an interesting chart - but no 126 x 11. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Matt S Posted September 23, 2018 Members Report Posted September 23, 2018 College Sewing in the UK lists several different sizes and styles of 126x11 needles in stock. Price is pretty reasonable so I suspect it may be a NOS item. You could grab a bunch and even if their supply is not sustainable you'll give yourself (a) a reference for what the correct needle is like and (b) time to find a longer-term source of a suitable substitute needle. A 111 that can sew 1/2" sounds bloody useful! Quote
Members dikman Posted September 23, 2018 Author Members Report Posted September 23, 2018 If they've got them then I'm hopeful that my local place should have them (or their stores interstate). If not I'll order some from College. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
