I’m kind of excited about this servo - is it just me or does it appear to have a squarish body as if it or a variant using the same form factor is perhaps NEMA sized to directly bolt up to a geared reducer?
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Don, if you're referring to the one R8R pictured it appears to be pretty much identical in construction to my servos (in other words, fairly "standard" construction).
I’d love it if there’s enough room on the front cover to match a NEMA 27 or 34 hole pattern.  The distance between the mounting holes is....wait for it.....2.7” or 3.4”!  Lol
this looks like a nema 27 bracket and the other is a planetary reducer that fits a NEMA size servo motor
Edited by DonInReno
Looks to be about 76mm (ish) spacing on the end plate mounting holes, with another set of holes inside those at 40mm to mount the belt cover bracket.
Interesting. I just checked mine, I have two types, a 550w and a 750w, same brand (Lishui). The 750w is 68mm and has a round front, the 550w is 70mm and has a square front like that planetary gearbox.
 I've still been searching both aliexpress and alibaba trying to find a match to that unit R8R has posted, but with no luck. I can't find any servos rated at 1100w, the closest is 800w, this model is a close match at 800w and the control panel appears to have the same functions (LT-800W, made by Lishui). There also don't appear to be too many that start at 100 rpm, all the ones I've looked at start at 500 rpm.
Curious.
  • 2 weeks later...
On 9/27/2018 at 10:03 PM, R8R said:
Hmm...the big Artisan looks awfully similar to your new servo?
Might be. The controller is different though I think, and that is where the magic happens.
The one from Keystone is $75 cheaper too.
Edited by R8R
Formatting
