Show me your tables! Im thinking of redoing my sewing table.. is it worth it?
So I have dabbled in a little wood working and was thinking of doing a butcher block style top for my Consew 206RB-2 machine.  Does anyone have pictures of their custom tables to give me ideas?
Should I just resurface the existing table OR make my own butcher block OR just buy a butcher block table top and cut out my own place for the sewing machine? or just stick with the old school green table and just focus on sewing dangit!
Here is a blog i found where the girl redid her table but I might want to replace the top and route out my own hole opening etc.
https://theprojectlady.com/trimming-collection-bag-for-industrial-serger-sewing-machine-diy-tutorial/
i LOVE the darker wood top and the flat black legs
the image below i think was before she painted the bottom flat black. like pictured above.
You might look this thread over.....
-DC
-DC
ahh shoot i didnt find it when i searched  :(i posted on that thread thanks!
Edited by myjtp
Do you have a picture of your table?  What kind of budget do you have?  There’s a thread that’s not too old down on the list that has a lot of custom tables.
There’s nothing wrong with refinishing a top if that’s the look you’re going for.  A plywood top with a little finish is functional, but it looks like a plywood top.
If you keep your eyes open for second hand butcher block it can be cheap for a 4’ section - or even free.  My day job involves remodeling a lot of kitchens and clients seem to think there is a lot of value in the old butcher block, until it sits in their garage for a week and none of their friends want it then it seems to go into the dumpster or one of our guys use some of it for a work table top.  Heck, if you lived closer I have a piece I’d give you.
New maple butcher block can probably be had for $100 or so - maybe even less if it’s a scratch and dent piece.  I’d try to find a regional supplier and simply stop by the shop where they glue it up and ask if they have any 4’ chunks you could buy for cheap.
that's a great idea! What type of shop do i look for?
The easiest and most expensive will be a place that sells rough sawn hardwood lumber to the public.  Most towns of any size will have such a supplier.  They might have a short piece with a little cup to it that’s essentially worthless as a countertop, but would be cheap - like $50. Normal price would be $100 for a top with short pieces glued end to end and probably $150 for all full length strips of wood. Walnut would be twice that.
These hardwood suppliers, local cabinet shops, and even some tile stores that stock butcher block will buy from a regional mill that cuts and glues the tops.  These mills will have a number of scratch and dent returns and tops that have cupped a little....many will simply get thrown away especially if they have any kind of customer applied finish.  These places will have multiple wood species and in addition to counter tops they’ll make butcher block game tops, bowling alley lanes, prison beds, etc.
Looking for deals if someone doesn’t have anything for you always ask if they have any advice for who might.
Is this top sagging to degree that's just un-cool.  I have seen some that are or have been oil soaked and have weakened the particle board.
This finally gives them a sag and may need attention. I have also had new ones from no usage but came from storage and banding on pallets that helped put a sag in them. With these I found a new metal frame constructed to brace these tops of standard factory option to be just the ticket.
Many of these machine heads really need more support and a good seal on the exposed wood surfaces that are near any oil.
good day
Floyd
These are such cool table tops!
Lumber Liquidators sells butcher block island tops. Pricey but you can get it in walnut, etc.
good day
Floyd
Now that I took a look BOTH are sagging! you are 100% correct! I could just buy two 2"x6"x8' boards https://www.homedepot.com/p/2-in-x-6-in-x-8-ft-2-and-Better-Kiln-Dried-Heat-Treated-Spruce-Pine-Fir-Lumber-161713/100037451 ( $6.04 each ) cut them in half and square up the edges glue them together making them 48" x 22" x 1.5" thick for $12.08 in wood ( buy some dark stain ) then route out the opening.  Would that work?
Menard"s is having a sale currently on their Butcher Block Top,  25" Wide x 48" Long x 1.5" Thick for $71.19 after mail in rebate.  https://www.menards.com/main/kitchen/countertops-laminate/all-countertops-laminate/butcher-block-top-25-wide-x-48-long-x-1-5-thick/4857016birchbblock25x48/p-1444430610144.htm
That's what I used on this patcher, it's the natural color with polyurethane..  They stock them at the store here in town.  I'll do it again if I have the need.
Edited by Evo160K
I have started on four table tops.  The photos below show what I have so far.
I went to the local hardware store.  In Australia, this is Bunnings - In USA it would most likely be Home Hardware to get what you want.
The beautiful decorative timber table top is precut to size and was one of numerous colours.  3/4" thick and precut to 2' by 4' (Metric 600x1200x20)  (It also comes in other sizes)  This size is almost exactly the same size as most of my industrial machine tables.
I glued and screwed it to 3/4" marine ply for the sake of extra strength and rigidity for the first two.  The ply was also precut - about 1/2" longer and wider than the decorative timber.  Cut to size first, before attaching.
You can see that I have routed the ply on two of the four table tops - I will do the same with the others when they are glued and screwed.
Next, I will lay the old table on some butcher paper to mark the size and shape of the hole for the machine.  Check that and cut and rout the new table tops - making sure I leave supports for the machines.
I will do some minor filling with putty, then sand, stain and coat with polyurethane.
All of my machines are Singers (look at the signature file below), and I have great original Singer industrial legs including heavy duty bases for those with motors and a couple of sets of excellent industrial treadle bases in perfect working order.  I will select the bases for each machine, attach them to the table tops and mount my machines.  looking forward to documenting the entire process.
I hope this gives you some inspiration.
9 hours ago, myjtp said:
Would that work?
Even kiln dried framing lumber has much more moisture than it will have at equilibrium with the conditions in your house.  It will shrink, twist and warp a considerable amount.  If you stacked that same lumber under your bed or behind the couch for 6 months so it has a chance to dry out then cut and glued it up flat it would turn out just fine.
G'Day,
I never really gave my sewing tables  that much thought , but heres mine .  The tables are the same ones that came with the machines . The only ' custom ' part of the table, is that daggy looking bit in the corner,  just above the drawers. ( I'm not a woodworker, as you can see  :blush:  ) I did that because I do horse rug repairs,  some canvas , & shade sail repairs,   and the extra bit of space became helpful. I could do with more, so   I will later add a bit more to it with an extra  folding extension right at the end going the full width of both the machine table & bench , as space is a prime , so when I get a sizable  job, I can fold it out.  I will also make a flat piece to fill the gap  to the right.
I just need to get a " roundtoit" ,...... never seen one in the shops though :):)
The drawers on the right , is where I keep my threads.
HS
Ahh great point! So if I go buy 2x6 from the big orange store and cut them right away and glue them together your saying they will eventually twist and shrink and crack?  So would getting the 4x8 oak ply be a better bet then?
I tell ya, you can spend a lot of money on a table top. I think if your looking for a wood grain as an interest thats cool.
But if your also looking for a custom sized or certain shaped table top. This I totally understand and can more easily promote.
In this above Im not trying to use my wants, its your funds. Rather just here as many offering a bit of historical info :)
I can easily say good quality plywood is above 60$ a sheet typicaly as I see the big box lumber stores. These are as you mentioned one style, a hardwod veneer type. The typical others are marine grade and the mdo used for various applications.
With the above material they are all easily better or more stabil than regular sheetings just by their wood spec., design and glue up.
We should recall truly why some gym floors, bowling alley lanes, butcher bloc tables and finally many furniture makers bench is understood with their build of this thin side by side glue up of woods.
The stability has long ago been known. If in stretching the stabil limit quality it we can and have seen in typical flooring, widen these widths a little.
It has been pretty well established that partical board is the stable go to for manufactures. As we all have some in cabinetry in our lives. I have found it is a very good product in many builds.
So in building any I sugest a three layer thick plywood or even particle board. I think if wanted, and access to some wood working tools you could as planed fabricat a nice table top, no doubts from here.
There are several glues one can use in a layer up build. What Im working up to is if your really hell bent on a wood grain.
I think a base material of partical board with a glued/laminated top layer of whatever. Be it the veneered oak ply as you mentioned or another actual thin wood in not wider than 2-1/2” width.
Additionaly you can always use a masonite layer for fine tuning in between a layered thicknes for certain measures needed. With some good landau glueing outdoors, this for sure “wood” work
In any of your choices 1-1/2 is bare minimum thickness imo, Just sayin some factory tops here. Now modified, that have a 2 x 2 angle steel frame supporting a singer and few juki 15? series. I guess they get heavier :huh: over time.
This bit above is only important on the imediate area of a machine table, and disregarded if implementing machine head into a big giant work table. As this would be better discussed on another path.
Happy trails
Floyd
I’m a big fan of Douglas fir and framing lumber can be an inexpensive way to build all sorts of furniture, but it can’t be used right off the shelf.
When framing lumber is kiln dried it’s moisture is in the 16% range.  “Sun dried” is between 16% and 19% and “green” lumber is 19% or more.  After Doug fir aclimates to your house it’s probably in the 9% to 12% range depending on how humid your particular house is.
To get lumber that’s at equilibrium with your house you can simply buy lumber and store it for a number of months until it stops shrinking and you can cut and glue it nice and flat and it will stay that way.  The easiest way I know to keep tabs on the wood is to simply measure once a week or month with a dial caliper on both ends and the middle.  You’ll see the ends dry out much faster than the middle.  If it dries out too fast the surface will develop checking (cracks) - if this is happening coating the ends with melted wax and maybe even loosely wrapping the boards in plastic. Eventually the boards will stop shrinking and they are ready to use.
Another source of dry framing lumber is in the classifieds or at a surplus building supply store.  Something that’s been around for at least a year is safe.  More and more people are interested in recycling and there are great deals on some very nice wood.
Edit:  this 6’x6’ table is built with framing scraps and a couple layers of 5/4” ply as a base for a tile top.  I selected straight grained scraps as they were available and coated them with a layer of varnish and simply set them inside the garage....about 9 months later they were stable and ready to be cut.
Edited by DonInReno
damn nice work!
  • 10 months later...
In England Butchers block is made up of the ends of the wood rather than the length, so a block would be made up of say 2"x2" ends glued together on all sides  so the end grain is the work surface to make a large surface
Same basic language but different meaning I guess
Being a newbie I don't know how common magnets are on tables but I do know that I love the magnet just under the veneer surface on my old Durkopp. The Singer doesn't have it. It's just so handy knowing you can almost throw the snips/needles or whatever on the table knowing they're not going anywhere. Whatever table you end up with, just give a thought to a magnet.
