Members Tstop64 Posted November 2, 2018 Members Report Posted November 2, 2018 Hi guys and girls I recently came into possession of this vintage sawing machine. It seems to be turning well but I have no idea how to thread the machine and what needs to be done to make it work, without cousing damage to it. Do I have to oil it before use? Any info would be highly appreciated. Thank you. Mark from Prague Quote
Members jimi Posted November 2, 2018 Members Report Posted November 2, 2018 Hi Mark, here is a link where you can download a manual for the singer 45k. your machine looks like a Adler 5-6 which are copy´s of the singer 45k so threading is the same. you should oil your machine before using but if it is moving ok the you wont do any harm to it. in the manual you can see where to oil and on the bottom arm look for all moving parts and holes. looks like your thread is a little too thin, 3 cord, T210 or Tkt15 bonded nylon and a nº 23 needle should get you sewing if there is no problems with the machine? did the previous owner have it sewing?? Quote
Members Constabulary Posted November 2, 2018 Members Report Posted November 2, 2018 I can send you ca PDF copy of the original German manual. Send me a PM with your email address if you are interested. Machine is missing the pre tension / thread guide for the bobbin winder - or maybe it in the drawer. Machine has no reverse - but thats not a too big issue Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Tstop64 Posted November 6, 2018 Author Members Report Posted November 6, 2018 Hi guys, thanks heaps for all the info, much appreciated, the machine is running well, I'm just being cautious as I don't want to mess up an old beauty. I was given tons of spares, needles and threads as well, shaping bones and sumsuch, so looking forward to getting this old lady to sing again. Cheers Mark Quote
Members Tstop64 Posted November 6, 2018 Author Members Report Posted November 6, 2018 Hi guys in the manual there's an oil reservoir where the thread passes through. What kind of oil was used for that and is that necessary with modern threads? Thank you Mark Quote
alexitbe Posted November 6, 2018 Report Posted November 6, 2018 no, its not necessary anymore... They didn't have waterproof manmade threats back then.... It was not oil Cheers Alex Quote
Members Tstop64 Posted November 9, 2018 Author Members Report Posted November 9, 2018 Hi guys, thanks again, what did they use to waterproof the threads? Cheers Mark Quote
Moderator Wizcrafts Posted November 9, 2018 Moderator Report Posted November 9, 2018 5 hours ago, Tstop64 said: Hi guys, thanks again, what did they use to waterproof the threads? Cheers Mark Liquid bees wax or other compounds that get into the linen fibers and harden after they dry. When I had Union Lockstitch machines I used Ceroxylon from Puritan Industries (the makers of Puritan chainstitch post and cylinder arm needle and awl machines). It is a clear liquid wax that air dries and locks the stitches and fills the holes when it dries. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Tstop64 Posted November 11, 2018 Author Members Report Posted November 11, 2018 Thanks for that, Much appreciated. Mark Quote
Members Constabulary Posted November 11, 2018 Members Report Posted November 11, 2018 there also SELARIS or FRANKEL stitching wax. Not sure where to get it on the continent but I think a Fiebings dealer should have FRANKELS. But nowadays most folks either use pre waxed thread (linen mostly) or polyester like SERAFIL so the wax pot often left unused. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
