Any help on punching a clean tip on the end of a strap? >>
Don't know if this will help but might work it does take a little practise
but once you get it you get it and once you get it you might find you can't help your self
any scrap leather you have you will have a little practise
hope this helps
JCUK
19 hours ago, Dwight said:
I have a similar problem with oval punching the holes for some of my belts.
How I've "cured it" is to first hit a very light stroke, . . . allowing me to see if it is where it should be, . . . adjusting if necessary, . . . then punching.
My belt holes have become significantly better since I started that practice.
Try it, . . . just might work for you as well.
May God bless,
Dwight
Great tip Dwight, thank you!  Kind of common sense but I've never thought to do it that way.
There are always possibilities....
Bob Blea
C and B Leathercrafts
Fort Collins, CO
Visit my shop at http://www.etsy.com/shop/CandBLeather?ref=si_shop
Instagram @bobbleacandbleather
Strap end punches are a lovely thing, but as you've found getting them lined up exactly can be a challenge.  If you're using them often enough, a jig might be the way to go.  I made one of these some time ago, but gave it to a friend that admired it with the intention of making an improved version for myself...Which I never quite got around to!  It would be easier to describe this with a drawing or picture than words, but here we go...
Get a cheap plastic cutting board, cut two strips off the ends an inch or so wide and make sure that the ends are square to the long side.  Glue or screw these to the cutting board at the width of your strap and dead straight across the ends.  In use, lay the belt between the strips then rest the "wings" of your strap punch right up against the skinny end of the strips.  Provided that the punch "wings" are true, that will help you get the angle just right, you then only have to worry about centering it.  If the "wings" are not true, you can either remove a little metal from the "high side", or adjust the positioning of the strip to compensate for that "high side".  If you're feeling ambitious, you can cut a little notch out of the business end of the strips that will just cradle your punch to get it centered as well.
I hope that description helps ... I'll try to put together a drawing at some point if words aren't helpful.
- Bill
Thanks Bill.
As mentioned though.  I do various widths and tapers, so can't use screw or glue down frames to hold the leather in place.
Good idea though for belt makers
Punch is sharp.  I hone it on water stones and then green honing compound to finish the edge
Thanks for the other suggestions
DON
The most-versatile method is to put away the punch and just use a sharp knife. Cut about a zillion 4" straps to practice with, and by the time you run out of practice straps it will be muscle-memory.
The technique is to hold the edge of a razor-sharp knife vertically and perpendicular to the edge of the table with your 'off' hand, and then you take the strap in your other hand, place it flat on the table with the side against the edge of the blade, and with a bit of a "swooshing" motion rotate that strap against the blade. Now flip the strap over and repeat. The resulting cuts should give you a nice English point.
At the start of this "swooshing" motion, the strap should be touching the blade at an acute angle, and the natural motion of your wrist pulls the strap through in such a way that the angle rotates through and traces the bottom of a Nike "swoosh" emblem, from the tip of the long end through the curve at the front, and eventually all the way trough the leather. When you flip it over and do the other side, the two sharper ends of the curve cuts come together in the middle to make the point. The biggest trick is making sure you start both cuts at the same "longitude" of the strap and use the exact same motion.
I don't suffer from insanity, I enjoy every minute!
www.rogueleather.com
  • 4 weeks later...
Made these jigs a while back. They are fixed width 1" and 1 1/4"
The strap lays in the groove and the tips of the punch press against the shoulder of the jig. The wider area of the jig is an exact fit for the punch which centers it. They work quite well.post-9957-0-25737500-1432494466_thumb.jpg
