Members Willb2862 Posted November 14, 2018 Author Members Report Posted November 14, 2018 First, thanksto all of you who took the time to post suggestions! I tried thefine tip markers anda paint brush tonight. The markers worked great on my scrap/test piece! Unfortunately, the color changed drastically when i tried it on the dyed belt. I then switched to a 10/0 brush and , as per the suggestion from ABH, reduced the paint. Worked fantastically! Here is a pic of where I'm at so far. I'll post more pics when the belts are completed. Thank you again to all of the great suggestions! Quote
ABHandmade Posted November 14, 2018 Report Posted November 14, 2018 (edited) Glad to be of help. Another little tip. When working with acrylic paint, one of the most unpleasant problems is the quick drying of paint on the palette. It is easily solved with a wet palette. I tried to depict it in the picture. It is necessary to moisten a napkin, but so that it does not ravel out. Paint on such a palette does not dry out for several hours. I use a closing palette (like the one in the photo), which I close during breaks in work. It also adds time. If I need to work the next day, I additionally put the palette in a zip-lock plastic bag for the night. Edited November 14, 2018 by ABHandmade Quote
Members Sheilajeanne Posted November 14, 2018 Members Report Posted November 14, 2018 What a great idea, AB! This sort of information is what makes it worthwhile hanging out here! Quote
ABHandmade Posted November 14, 2018 Report Posted November 14, 2018 3 hours ago, Sheilajeanne said: What a great idea, AB! This sort of information is what makes it worthwhile hanging out here! Thank you, Sheila. The idea, of course, is not mine. I met the description of the wet palette a few months ago and was able to make sure that it really works. Before that, I was afraid to work with acrylic paint, because in my first experiments it dried on the palette in just a few minutes Quote
Members Willb2862 Posted November 14, 2018 Author Members Report Posted November 14, 2018 AB, thank you! Grabbed the same palette today, and used your method. Paint stayed wet and usable even after 2-3hr break! The belts are turning out great, thank you again! Quote
ABHandmade Posted November 14, 2018 Report Posted November 14, 2018 Glad this turned out to be useful for you, @Willb2862. Quote
Contributing Member JLSleather Posted November 14, 2018 Contributing Member Report Posted November 14, 2018 5 hours ago, ABHandmade said: The idea, of course, is not mine. I met the description of the wet palette a few months ago That's a cool tip, and it's SO WAY refreshing to hear somebody openly state that he didn't INVENT EVERYTHING that ever existed Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Tinkerton Posted November 15, 2018 Members Report Posted November 15, 2018 One question I have, is what TYPE of brushes are you using? Different brushes are designed for different types of paint. Are the bristles soft and pliable, or are they stiff and hold their shape? For acrylic paint, you want a stiffer brush to hold up to the thicker paint. Using too soft a brush will make for sloppy lines and poor control. Quote
Members Willb2862 Posted November 16, 2018 Author Members Report Posted November 16, 2018 I am using acrylic brushes. Stiff bristles. Quote
Members Willb2862 Posted November 29, 2018 Author Members Report Posted November 29, 2018 I apologize for the delay in getting these posted, been very busy with work. Here are both of the belts completed. I couldn't be happier with the results of the painting, amd im sure the kids will love them! Thank you for all the help! Quote
