Members Sterlclan1 Posted January 27, 2020 Members Report Posted January 27, 2020 On 1/6/2020 at 6:15 PM, Rockoboy said: Is it possible to print this type of thing with a smooth surface? That grooved surface might be undesirable to a lot of people. cura has the option of ironing the top for a smoother finish.its in the advanced settings Quote
Members sbrownn Posted February 9, 2020 Members Report Posted February 9, 2020 On 11/22/2018 at 9:28 AM, chrisash said: No glass bed just a special top made for the ender, taken me a long time today to get it leveled, i think the next purchase will be a auto level kit It seems very like leather work, the more goodies you buy the more you want or need and as my grandson says" I I I Neeed it" aged two Leveling is overrated. The machine will easily compensate for things not being perfect. I level the bed of my Flashforge at three points in less than two minutes and it works fine. Quote
Members sbrownn Posted February 9, 2020 Members Report Posted February 9, 2020 On 11/29/2018 at 2:43 AM, RockyAussie said: Congratulations @chrisash on getting a very worthwhile tool. Be patient and do a lot of getting used to your settings and how the can vary before trying to do too much too quickly. Lots of things like your temperature in different colour filaments and ideal bed temperatures for the given filament and a hundred other various adjustments, can make a big difference to the outcome. I have had a lot of health issues of late and along with a huge backlog of work to catch up on I am sorry I am limited to the help I can give you in a hurry. In order to help some with the above questions I can say that the pla+ has worked excedingly well with the stamp project I am currently working on. I am still working on this project at the moment and will give a more full break down of it over the next week or so but here a a few pictures to help show you more of what I mean. I should start by saying that the stamps in this case are a letter set that I have designed a font for that I want to use for stamping onto belts that have to be painted in different colours as well. This involves the use several different processes including the 3d printer and a 2.5 watt laser as well as a clicker press and so on. First I designed a guide to hold the letters which were going to be used with the Ivan letter set. As I could not get a font for the laser work I then designed my own. The following pic shows my stamp test held up well to the hammering down with the clicker press. This one shows that the Ivan letter set is thinner and a bit smoother but I have not bothered to smooth out the pla+ printed ones either. This one just shows where I am testing the line up of the laser cut masking tape with my stamp. AS you see I did not have it quite aligned as needed and I have to say that the thickness of the letter width is only .77 mm so it does take a little patience. There's that word again. Oh nearly forgot.... the letter height I used 2.5mm high off the block and 2mm wide at base extruding up at -15 deg inside the letter and 15 degrees outside the letter. I work in Autocad unfortunately so I cant help much in the other programs. Brian Very nice. I had a fly press I used in my CAD class and I wish I still had it. Quote
Members sbrownn Posted February 9, 2020 Members Report Posted February 9, 2020 On 1/6/2020 at 3:15 PM, Rockoboy said: Is it possible to print this type of thing with a smooth surface? That grooved surface might be undesirable to a lot of people. That can be easily solved by using a two part mold that, when the sides bottom out, has a little extra clearance between the top of the male mold and the bottom of the female mold; no marks. On 1/6/2020 at 10:00 PM, Rockoboy said: I think I can see a 3D printer in my immediate future! It's my most used leather working tool. Quote
Members sbrownn Posted February 9, 2020 Members Report Posted February 9, 2020 On 11/29/2018 at 1:30 PM, dikman said: I'm not. Unfortunately 3D printing requires a fair bit of effort to sort out, as you're finding out. I suspect that for most it's either too daunting a prospect or they don't have the time. Brian, sorry to hear you've been on the sick list, hope you're on the mend. It's the CAD that takes some time to get competent at. The 3D printing part just goes to work on the CAD files. If you have a local university, sign up for a CAD class and you will learn more than you ever need to know and have fun doing it. Quote
Members sbrownn Posted February 9, 2020 Members Report Posted February 9, 2020 On 1/16/2020 at 5:58 PM, garypl said: First attempt at making a mold and didn’t know how strong the outer frame should be. Turns out it seems plenty strong - maybe I will make the next one a bit thinner. Takes me only a couple of minutes to level the bed using a piece of paper as a feeler gauge. The critical part is actually where the top meet the outer frame; it needs to be thick enough to keep the sides from splaying out when pressed. I design my molds to shape dry bridle leather because I don't want the color change that results from getting it wet. Thicker leather takes a stronger mold...obviously. On 1/27/2020 at 3:55 PM, Sterlclan1 said: cura has the option of ironing the top for a smoother finish.its in the advanced settings So that means an automatic change to a higher resolution print on the top layer or more heat? What is the software actually telling the machine to do? Quote
Members Sterlclan1 Posted February 16, 2020 Members Report Posted February 16, 2020 On 2/9/2020 at 6:40 PM, sbrownn said: The critical part is actually where the top meet the outer frame; it needs to be thick enough to keep the sides from splaying out when pressed. I design my molds to shape dry bridle leather because I don't want the color change that results from getting it wet. Thicker leather takes a stronger mold...obviously. So that means an automatic change to a higher resolution print on the top layer or more heat? What is the software actually telling the machine to do? it smooths the top surface by running the nozzle over the last layer while feeding just a little filament it moves in the opposite direction of the last printing movement and fills the ridges smooth.no more heat just melts the top smoother Quote
Members sbrownn Posted February 17, 2020 Members Report Posted February 17, 2020 On 2/16/2020 at 4:04 AM, Sterlclan1 said: it smooths the top surface by running the nozzle over the last layer while feeding just a little filament it moves in the opposite direction of the last printing movement and fills the ridges smooth.no more heat just melts the top smoother Thanks, that's good to know. Quote
