Members JazzBass Posted December 15, 2018 Members Report Posted December 15, 2018 On 12/10/2018 at 8:35 AM, immiketoo said: ...In Pic one, you can see the area around the hair is smooth except for the lines for the branches. The figure beveler pushes down the leather smoothly and makes your art stand out. In the second pic, you can see our the branches are behind the birds and Odin, but above the background. Also you can see the transitions on the celtic weave. Hope this helps. Wow, Mike - once again, your carving is off the hook, and SO darned CLEAN! Inspirational, my friend! Quote Christopher J. Gordanhttps://www.youtube.com/user/ChrisGordan
Members fiftycrushplan Posted December 21, 2018 Author Members Report Posted December 21, 2018 Here is an update I re-done the piece with your alls advice and used antique gel. I like this one much better. Quote
Members JazzBass Posted December 21, 2018 Members Report Posted December 21, 2018 Yup - better and better ! Feels pretty good, doesn't it? Quote Christopher J. Gordanhttps://www.youtube.com/user/ChrisGordan
Members YinTx Posted December 21, 2018 Members Report Posted December 21, 2018 Looks a lot better. If you want to clean up the outside portion, use a damp towel to scrub off some of the antique. Also, sheep wool with 50/50 tankote works really well too, and helps seal in the antique when it dries. DId you use Fiebeng's paste, or did you use an acrylic antique? YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members fiftycrushplan Posted December 21, 2018 Author Members Report Posted December 21, 2018 39 minutes ago, YinTx said: Looks a lot better. If you want to clean up the outside portion, use a damp towel to scrub off some of the antique. Also, sheep wool with 50/50 tankote works really well too, and helps seal in the antique when it dries. DId you use Fiebeng's paste, or did you use an acrylic antique? YinTx I ordered the fiebings antique dye but I also got the eco flo and I used the eco flo on this one. I thought it looked better when I was testing it out. I used 50/50 resolene to water for finish as all I have is resolene and aussie conditioner. Quote
Members YinTx Posted December 22, 2018 Members Report Posted December 22, 2018 If you have already put the seal coat on, it will probably not change much from what you have. In the future, try a wet towel to even out the antique outside of your tooled areas when using acrylic antiques like the eco flo, you may like the results. Also, applying tankote 50/50 before and allowing it to dry 8hrs before antique will give a different (lighter, more evenly colored) look as well. YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members Sceaden Posted December 22, 2018 Members Report Posted December 22, 2018 Definitely a big improvement! Quote
Members fiftycrushplan Posted December 26, 2018 Author Members Report Posted December 26, 2018 Thanks everyone! I have been meaning to get some tan kote for a while now. If I am not mistaken will tan kote smooth out the fleshy side of leather as well? Or is that edge coat? Thanks all for the compliments. It does feel pretty cool to say I have gone from mere sheath maker to tooling apprentice LOL. Quote
Rockoboy Posted December 29, 2018 Report Posted December 29, 2018 On 27/12/2018 at 3:30 AM, fiftycrushplan said: will tan kote smooth out the fleshy side of leather as well? I believe what you need is Gum Tragacanth. Apply a thin coat then burnish with a smooth burnishing stick. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members YinTx Posted December 30, 2018 Members Report Posted December 30, 2018 As Rockoboy mentioned, gum trag will work. I tend to use Tan-Kote to slick the back of leather, and it works well for me. I've heard of some using Resolene for the same purpose. I just apply, and slick with a glass slicker until dry and smooth. YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
