anyone else feel like the Tandy snaps dont hold very well? I'm having them pop open on some of my larger sheaths that take two snaps. I think the ones I got at ACE hold stronger (but dont come in black).
What snaps do you like and dislike?
I'm going to try the Ohio travel bag snaps as I hear they also come in extra long posts
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
I use the snaps from The Buckle Guy.  Made from solid brass and have never had an issue with them yet.
  • 3 weeks later...
Hey! Since we're on the subject of snaps, are there snaps where the "shank" or "stem" or whatever you call it is longer than what seems to be "standard"? I have run across snaps described as "Line 24" which I think are longer but I can never seem to find any actual dimensional specs on these or any other snaps.
I need to make it through 4-5 mm of leather with the head (the pretty side). Where that goes is actually a couple of layers.
I have been doing my own searching, but getting nowhere because whatever i find is totally lacking in any sort of relevant info.
So anything out there? Or do I need to reconsider my design to figure out some way to have where the snap goes come out thinner?
You might check this link: https://www.buckleguy.com/brass-snap-fasteners/. The Buckle Guy offers short, regular and long posts. When you click through each item, you will see the post length displayed. Hope this helps.
Oh Awesome! :) Now I see I have multiple choices.
Which raises a question, any kind recommendation on a minimum/maximum on how far above the leather the post should be sticking out?
Obviously too short and the post won't grab. (Figured that one out for myself already. :crazy: ) But what about too long? I would guess that there is a point where too much post material sticking up makes it impossible for it to be pressed down and grab securely also.
Again thank you! As soon as I get my post lengths figured out I'm placing an order.
I buy all of the various lengths, then experiment to see which one works best. Some leathers are thicker, and some leathers are softer, so you won't know until you set the snap. On occasion, I have had to use my trusty Dremel grinder to take off some of the length to get the posts to seat properly. The best investment I've ever made is a bench mounted snap (and rivet) setter.
AHA! OK I get it. Too much is dependent upon the qualities of the leather itself. Cool. I'll figure something out.
I have a bunch of snaps that have been working for other products. So I'll measure those, figure out what they are and start with just going one post length longer for this new product.
You should have 1/8" to 3/16" through the leather to ensure ample security when you set it.  Same goes for rivets.
