Members Instinctive Posted December 21, 2018 Members Report Posted December 21, 2018 I am setting up my first sewing machine, a Consew 226R-1. Sews really well with 3 layers of 8 oz leather and 138 thread. It came from an upholstery shop so was basically set up for thinner material. I understand the machine presser feet can lift up to 1/2". Right now the presser feet lift about 3/8" and when sewing they walk with a lift of about 1/4". Old manual and my unfamiliarity with these machine have me handicapped to make the necessary adjustments to raise the feet for better clearance. Can someone advise me the proper procedure for: Increasing the stationary lift of the presser feet to 1/2". Increasing the walking lift to provide clearance for the thick sewing if that is possible. Thank you. Quote Eric Fisher Fisher Custom Leather "A Retirement Project" https://fishercustomleather.wordpress.com/
Members dikman Posted December 22, 2018 Members Report Posted December 22, 2018 A quick search turned up this, it tells you how to adjust the feet. CONSEW+226R-1+INSTRUCTION+MANUAL.pdf Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Instinctive Posted December 22, 2018 Author Members Report Posted December 22, 2018 12 hours ago, dikman said: A quick search turned up this, it tells you how to adjust the feet. CONSEW+226R-1+INSTRUCTION+MANUAL.pdf Thanks. That is the same manual I have. Diagrams are really bad but thanks to a good setup video for a Juki LU-563 I found and that manual, I think I have been able to sort it out. Was able to get the clearance I need for 3 layers of 8 oz leather. When doing that it seems that I would need to readjust to do thinner material. Is that the norm? Quote Eric Fisher Fisher Custom Leather "A Retirement Project" https://fishercustomleather.wordpress.com/
Members Tejas Posted December 25, 2018 Members Report Posted December 25, 2018 Chapter 4 of NAVEDTRA 14217 which includes the Consew 225, which I think lacks reverse but might be similar, might help. On page 4-9: 2. Adjusting the total relative lift of the alternating pressers The total relative lift of the alternating pressers referred to here is that the feet lift one-half inch at total lift. .... http://militarynewbie.com/wp-content/uploads/2013/11/NAVEDTRA-14217-Aircrew-Survival-Equipmentman-1-C.pdf Quote
Moderator Wizcrafts Posted December 25, 2018 Moderator Report Posted December 25, 2018 Every now and then I experiment and switch my long body walking foot machine to use System 190 needles. I find that any gain in needle stroke is virtually offset by having to lower the presser foot to clear the bottom of the needle bar's thread guide. Unless a machine was designed to use System 190 needles, you will need to file or grind something out to get the full benefit of the longer needles. The hook timing and check spring throw also needs changed. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Peasantlizzie Posted January 14, 2023 Members Report Posted January 14, 2023 On 12/22/2018 at 5:26 PM, Instinctive said: Thanks. That is the same manual I have. Diagrams are really bad but thanks to a good setup video for a Juki LU-563 I found and that manual, I think I have been able to sort it out. Was able to get the clearance I need for 3 layers of 8 oz leather. When doing that it seems that I would need to readjust to do thinner material. Is that the norm? I'm not very familiar yet with how this site works, so hope this gets posted in the right place. Eric - I know this is an old post, but I'm currently struggling to adjust the presser feet on my Seiko stw-8b and wondered if you could post a link to the Juki video you mention. Quote Lizzie, UK
Moderator Wizcrafts Posted January 14, 2023 Moderator Report Posted January 14, 2023 5 hours ago, Peasantlizzie said: I'm not very familiar yet with how this site works, so hope this gets posted in the right place. Eric - I know this is an old post, but I'm currently struggling to adjust the presser feet on my Seiko stw-8b and wondered if you could post a link to the Juki video you mention. I guess you don't use the Google search engine or you would have found these results on that very subject: Setup video for a Juki LU-563 Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Peasantlizzie Posted January 15, 2023 Members Report Posted January 15, 2023 Is that meant to be sarcastic? I hope not because if so then I will be put off asking questions on this site again. Yes I do, and did, use "the Google search engine" and other ones too, but had not been able to find what I thought might be that particular video. Thank you for the link - I will look it up. Quote Lizzie, UK
Members Quade Posted January 15, 2023 Members Report Posted January 15, 2023 Knee lift always seems to be higher than manual lift. My manual lift is something like 3/8" whereas my knee lift height is more than 1/2" (13mm). My machine came with a little solenoid that would bump the lift when you encountered a thicker part. It connected to the lift arm that sticks out the back of the machine to give an temporary additional lift. There are mechanical limits to lift which seem to be different from machine to machine. I doubt mine will go any higher than 13mm by the knee lifter. Quote
Moderator Wizcrafts Posted January 15, 2023 Moderator Report Posted January 15, 2023 1 hour ago, Peasantlizzie said: Is that meant to be sarcastic? I hope not because if so then I will be put off asking questions on this site again. No, because iPhone users don't normally have Google Search installed. I have an Android phone and Chrome browser on my computer and only use Google search to find stuff. I don't know what results would show in an iPhone or Mac computer search for that video. Also, YouTube is part of Google. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
