Members gengado Posted December 26, 2018 Members Report Posted December 26, 2018 Could you give me some advice to improve this wallet the layers inside is goat leather Quote
bikermutt07 Posted December 27, 2018 Report Posted December 27, 2018 (edited) Most of what I would be unhappy with are things that come with practice. Stitching, edge treatment, cutting, and thread/needle combination. You have made a personal item that is totally functional. Be proud of that my friend. Show it off to your friends and they will never see the flaws you and I see. All that being said.... Slow down and take your time. Learn to sharpen whatever knife you are using. It takes a super sharp knife to get clean cut lines. Then get yourself a little sand paper. Sanding lightly along the edges will really clean it up. Try not to press to hard when sanding and Burnishing. It causes a mushroom effect along the edge. If you are using edge paint along that edge, do all the sanding first. Get yourself a pencil to apply the edge paint. Just roll the tip along the edge and put it on in very light coats. Sanding a little between each coat. Allow for plenty of drying time between coats. Get yourself a wing divider and use it along the edge to make light straight lines for your stitches. Make sure your awl, stitching chisels, or pricking irons are on your line and perpendicular to the leather before piercing. Some smaller thread on a wallet will look a little better as well. It all takes practice and time, but you are well on your way. In a few months you will be blown away at how much better you can do. Good luck and keep having fun. Edited December 27, 2018 by bikermutt07 Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members gengado Posted December 27, 2018 Author Members Report Posted December 27, 2018 i'm very benfited for your advices your insiration bikermutt07 Quote
Members battlemunky Posted December 27, 2018 Members Report Posted December 27, 2018 It doesn't look bad at all @gengado. Main thing I can see aside from the edges is to get the tension on your stitching right when using soft leathers like goat. It tends to bunch up when its pulled too hard. This comes with some practice and feel and time. Looks good for the most part, keep it up! Quote
Members gengado Posted December 27, 2018 Author Members Report Posted December 27, 2018 1 hour ago, battlemunky said: It doesn't look bad at all @gengado. Main thing I can see aside from the edges is to get the tension on your stitching right when using soft leathers like goat. It tends to bunch up when its pulled too hard. This comes with some practice and feel and time. Looks good for the most part, keep it up! thank you very much Quote
Members Ragingstallion Posted December 27, 2018 Members Report Posted December 27, 2018 they both hit it on the head for me, clean up the edges, smooth them out, and as mike said, tension on the thread. only thing I would have changed is using the same thread for all of it. i personally like sinew for looks, and tends to be a bit stronger, although it does like the separate a lot easier as your stitching. Quote
Members rodneywt1180b Posted December 28, 2018 Members Report Posted December 28, 2018 Your work is improving. Keep at it. Quote
