Very nice, but it seems to me the holes are a bit big in relation to the thread.  If using an awl, maybe size down to a narrower blade.  The slits should nearly disappear after stitching and tapping with a smooth-faced hammer.  Love the colors.
23 minutes ago, Rbarleatherworks said:
Beautiful work YVO, curious as to where to buy that leather from ?
Or are you going to keep it a secret:rolleyes:
Heh!  ;)
Rocky Mountain Leather: https://www.rmleathersupply.com/
I also get my Tiger thread from there which this wallet was stitched with.
CB 3200, Consew P1206RB, Craftool Pro burnisher, 3000mw desktop laser engraver, PointZero Dual Action Airbrush, Psuedo regad, HF 20 ton clicker, Silhouette Cameo and Cricut
Thank you.
I used KS Blade pricking irons. I used .6 thread and I probably should have used .8 or maybe even size 1 although I have a suspicion #1 would have been to thick. And you caught me - I did not roll or hammer the stitching when I finished. :)
16 minutes ago, VYO said:
Heh!  ;)
Thanks your awesome... I will have a look :)
I think your wallet came out awesome.  Looking at the backside of your stitching, I don't think your thread is too thin.  Possible one leather has a different temper than the other, and results in the tension showing differently on each side.  Front side looks fine, maybe less tension on the front would help keep the holes from appearing oversized.
YinTx
@YinTx Thanks!
I have another in the works using the same materials with a different internal configuration so I'll lighten up on pulling the thread through the top side and see if that helps with the holes.
